I've notice that BMW have used a very thick, tough, almost rubberized paint on many "hard" parts like fuel tanks, strut bodies and the like.
Does anyone know how to replicate this finish? Is there a specialised product out there? Or is this just a hammerite job?
Painting hard parts.
Phatz
The Sport - Gone to a new home to be slowly brought back to life
e30den
Powder coating will achieve the desired effect
Phatz
Ah, sounds stupid but I've never actually had any powder coating done. So, I'll be doing plenty of it soon.e30den wrote:Powder coating will achieve the desired effect
e30den
Engine paint is also good
drewjak
a body shop can supply the right stuff its nothing like powder coating!!!! it needs to be spray applied, powder coating is brittle and chips, this stuff is rubberised for a reason ,so it does`nt chip off exposing metal to the elements thus going rusty
Phatz
Any idea what the correct stuff is called mate? Cheersdrewjak wrote:a body shop can supply the right stuff its nothing like powder coating!!!! it needs to be spray applied, powder coating is brittle and chips, this stuff is rubberised for a reason ,so it does`nt chip off exposing metal to the elements thus going rusty
gare30
i think you mean spray sealer a good spray sealer gun can be set up to give you the correct finish to look original
drewjak
no this stuff is different its the same stuff that most german car makers use, i think you mean stone chip stuff which is crap compaired to this stuff, ill find out what it is when i go to work tomorowgare30 wrote:i think you mean spray sealer a good spray sealer gun can be set up to give you the correct finish to look original
octanejunkie
gare30
try sanding the textured parts down u will soon know that its a form of spray sealer as its like rubber to flatten of stone chip is harddrewjak wrote:no this stuff is different its the same stuff that most german car makers use, i think you mean stone chip stuff which is crap compaired to this stuff, ill find out what it is when i go to work tomorowgare30 wrote:i think you mean spray sealer a good spray sealer gun can be set up to give you the correct finish to look original
Phatz
It's defo some kind of rubberized paint/coating that seems very tough. I just want to know what the product is so that I can redo various parts that need it...
Would BMW know?
Would BMW know?
