Which oil do you recommend for my sunroof?
someone told me that there is a special oil ... or can I use a normal wd 40?
thanks
Best oil for sunroof
davpkav
I use spray-on grease for mine. Works great. Not sure if there is a 'special oil'?
GWB
- **BANNED**
spray grease or wd 40 should be ok, its what I use but remember
that both products will hold onto bits of dirt and grit and stuff
so as the vicars wife said; keep it clean.
Never argue with an idiot. They bring you down to their level then, beat you with experience.
