Cleaning BBS 'basketweaves'
rabbit2
Post Sun Feb 07, 2010 8:24 am
Does anyone know of the best way to clean BBS 'basketweave' wheels?
They sure attract muck. I went for a drive today for 80 km south of Canberra, Australia and wheels I cleaned recently need cleaning again.
At 26 degrees C there was no snow of course and the hood of my cab was down.
My previous cab had 'bottletops' which were far easier to keep clean and I think also looked fine although many on this board seem to dislike them.
Cloggy Saint
Post Sun Feb 07, 2010 8:39 am
Water, a cleaning agent, and a suitable brush. It's not rocket science mate!
beemerbird
Post Sun Feb 07, 2010 8:40 am
I've heard that one toothbrush and several hours are required 8O
lukescott
Post Sun Feb 07, 2010 11:01 am
Then polish them and use wheel sealant. Build it up over a few applications and the dirt will wash off the next time.
Martinaston
Post Sun Feb 07, 2010 11:15 am
spray on Active 8 (a mild acid) and jet wash off.
There is NO nucleus.
lowey
Post Sun Feb 07, 2010 12:18 pm
The best stuff I've found over the years is "wonder wheels" and is available from Halfrauds.
Kos
Post Mon Feb 08, 2010 2:44 am
Martinaston wrote:spray on Active 8 (a mild acid) and jet wash off.
and
lowey wrote:The best stuff I've found over the years is "wonder wheels" and is available from Halfrauds.
probably the worst things you can use UNLESS they are realy bad. and even then i'd be carefull
a general all purpose cleaner will do ( the meguires one is fine) and can be mixed as you like be it 1:1, 4:1, 10:1.
personaly i mix it up at 4:1 with water, and its spot on to clean my wheels once a week.
brush wise, a soft bristled one that gets in and out of all the gaps will do.
you'll find a few on the shelf in halfords
AlpineAde
Post Mon Feb 08, 2010 7:27 am
For mildly dirty wheels I've found that BMW's own wheel cleaner to be quite good. Otherwise ~ and I've just started using this ~ AutoGlym's wheel cleaner, a soft brush (as Kos suggests) and a good jet of water does wonders. I've never really had completely filthy 'weaves though, so I'm not in a position to suggest something for that scenario.
powelly
Post Mon Feb 08, 2010 8:19 am
It's good for cleaning brick work, that's where this stuff has it's roots. Depending on how bad the wheels are I would use either your car wash/shampoo solution or Valet Pro Bilberry wheel cleaner, the only time I ever use an acid based cleaner is on wheels with heavy baked on brake dust and only in extreme cases, use a selection of brushes, I use these brushes.
http://www.monzacarcare.com/products/?c ... rch%20term
and
and
http://www.cleanyourcar.co.uk/wheels-an ... d_389.html
and
http://www.cleanyourcar.co.uk/wheels-an ... d_390.html
Image Le Mans Classic 2006
bobbin1982
Post Fri Feb 12, 2010 8:41 pm
ARGH i bought wonder wheels from tesco the other day...
I have used it onece but not again :)
Driving my digger!!!!
powelly
Post Sat Feb 13, 2010 12:10 pm
Don't worry too much, as long as there is no broken paint on the wheel you should be ok, just don't use it all the time.
toby
Post Sat Feb 13, 2010 12:54 pm
The best thing I've found is a soft brush that clips into the hose - water and brushing at the same time. So much quicker than using a normal brush!
PG325
Post Sun Feb 21, 2010 7:15 am
I always used WW in the past but after joining a detailing website forum switched to Bilberry on others recommendations. WW is acid based and not good on the paint.
Bilberry dilutes anything down to 1:10, spray it on, give it a quick brush (if needed) and spray off, great stuff and non acid, wouldn't go back now. My 5 Litres has lasted nearly 2 years and only cost approx £23.
One point - Bilberry is very good on regularly cleaned wheels, it won't disolve baked on dust without several applications and then it might need a bit of rubbing.
gareth
Post Sun Feb 21, 2010 12:07 pm
i took the easy option and painted them satin black - the same colour as brake dust! :D
dano0
Post Sun Feb 21, 2010 7:45 pm
i cleaned my sisters mini wheels with cif and a nylon srunchy the type the mrs uses in the shower this was after tfr and wonder wheels did not shift the brake dust .im not by any means recomeding this. after i washed the wheels with wash and wax and they looked mint and apparently are now 99% germ free
and my wife is still looking for that scrunchy :D
BMJG
Post Sun Feb 21, 2010 8:32 pm
I used tesco cheap and nasty oven spray cleaner on some wheels that had very hard baked on crap,good hard scrub and washed off well did a great job. Would not do this to wheels only needing quick clean these wheels looked like had never been cleaned ever before
maddogg
Post Thu Feb 25, 2010 8:59 pm
Autoglym do an 'acid free' wheel cleaner suitable for all finishes which is what I use with a soft brush. I clean my wheels at least twice a week which is a real pain in the ar$e but good to keep on top of it...
Bluto
Post Sun Feb 28, 2010 1:57 pm
Bilberry is a stong alkline, so still need to be careful with it.
I am using Diablo at the moment.
Vikan wheel face brush, envy brushes and viken long reach for the inners.
