Peanut butter ?
IB6376CY
Member "rrs" refered to using peanut butter regarding the changing of tweeter speakers, this is a new one one me, can any one elaborate (or did I read this in Viz)?
beemerbird
Peanut butter is allegedly good for restoring black plastic parts on cars (it's the oil in it that does the work).
I have just consulted my partner who is an Acoustic / Sound System Consultant. He suggests that peanut butter is best suited to Toast
TPS
Yes Peanut Butter I can confirm is good for that,I have tried it, but use the smooth stuff, the nutty stuff it makes a hell of a mess
IB6376CY
.......and Marmite ?
beemerbird
Marmite isn't for everyone, so tread carefully.
gooner1
- Out humping Reindeer
Marmalade is good for restoring shabby cloth seats.
Please don,t try this at home.
BEERBOY123
Give it up! Anything you find in the pantry is almost guaranteed NOT NOT NOT going to be better than Autoglym/Maguars/Any Brand - whatever.
Don't be a pikey all your life!
beemerbird
Not true. I thought it was a well known fact that 'Gentleman's Relish' is a perfect replacement for both a 325i head gasket and the timing chain on the E30 M3.BEERBOY123 wrote:Give it up! Anything you find in the pantry is almost guaranteed NOT NOT NOT going to be better than Autoglym/Maguars/Any Brand !
IB6376CY
This is getting silly...but thanks for the response gentlemen!
Kos
i think its ground nut oil you could be on about
it helps remove polish compounds from plastic surfaces ( grainy ones like bumper trims)
Does it work Kos? And more to the point, does it last?Kos wrote:i think its ground nut oil you could be on about
Another one I've heard is that if you clean you passengers seat with Special K, your wifes arse gets smaller
tez180
Peanut buter works but is very messy and do not do it in public ;)
Whereas ground nut oil does the same job and easy to apply.
Personally I just give the said plastic a good scrub with a strong brush (tooth) and a strong mix of a all purpose cleaner. Dry. Then add my plastic care product.
TPS
What I've discovered with my van, when some stupid Fork lift driver bangs the back plastic bumper & leaves a nice mark on it (usually red), get a scrubbing brush & washing up liquid, scrub & leave for a day, wash off, hey presto, no more marks!
Kos
ha haB7 wrote:Does it work Kos? And more to the point, does it last?Kos wrote:i think its ground nut oil you could be on about
that explains the left over crumbs in the drivers seat of your e36 cab
beemerbird
I believe that the ground nut and the peanut are one and the same.
IB6376CY
The peanut is a type of goundnut as the nut grows in the ground. But we are talking peanuts here!
rrs
I never suggested peanut butter was better than any brand name trim gel/wax (none of which provide a permanent solution)simply that it does provide a good lasting finish on certains types of plastics and is a darn sight cheaper.BEERBOY123 wrote:Give it up! Anything you find in the pantry is almost guaranteed NOT NOT NOT going to be better than Autoglym/Maguars/Any Brand - whatever.
I'm happy to use it on my car which I feel is far from pikey but as it has just started to wear off my rear numberplate surround(after nearly 6months) the next thing I want to try is the heatgun method.
Bluto
Have used the smooth peanut on faded plastics and did ok.
However I have just used swissvax plastic cleaner and that did a good job followed with seal feed. (and thats not a kipper)
m_jermyn
Ide be wary of stray dogs licking my bumper trimsrrs wrote:I never suggested peanut butter was better than any brand name trim gel/wax (none of which provide a permanent solution)simply that it does provide a good lasting finish on certains types of plastics and is a darn sight cheaper.BEERBOY123 wrote:Give it up! Anything you find in the pantry is almost guaranteed NOT NOT NOT going to be better than Autoglym/Maguars/Any Brand - whatever.
Bluto
A few compaines are now selling plastic/rubber sealants.
I have 2 at the moment to try.
One has been on the GFs car now for 2 months, it seems to be ok, but it is in the engine bay so gets little proper grime but does suffer more heat.
If faded to much, I would look at getting them painted black rather than heating them.
dazleeds
- old skool raver
www.oldskoolfantasy.co.uk
chris_335
not to bad on tost
