And would you be able to use it on a parcel shelf?
Ollie is strange and wants to dye his dark carpet beigepoolnoodle wrote:I dyed my beige carpet and it came up nicely - not black but and OE looking dark grey / charcoal. It cost me about $60 to get the dye delivered by a local company but I believe Valet's Choice in the UK have the same product.
1. Cleaned carpet with high pressure cleaner
2. Applied three coats (dry in between) at specified dilution. Carpet won't absorb any more coats than this
3. Hit with HP cleaner again to remove any stray dye
Here are before and after pics
I used the kick panel carpets for a test as I replaced them with plastic items from later model.
I used a rattle can of vinyl dye to do the heel pad and edging.
I got the parcel shelf retrimmed to match as the original carpet was too badly sun damaged. It only cost about $50
