hi, everytime i brake gently or harshly it feels like my abs kicks in, its like a click on the pedal and makes the noise a abs makes.
sometime the abs light comes on, then the brakes are fine
could it be a relay, where is the relay?
thanks Ray
ABS playing up
E3OBM
looking for a 325i cab for a project. why?
f4stjay
Try Technical Help for a better response but have you had your wheel off to see if there are any teeth missing from your ABS reluctor ring? I had the same thing on a car I traded once and that was the cause of the issue...
'90 325i Sport
