Cleaning a LSD
E30ISMIKE
Post Sat Jun 28, 2008 11:09 pm
Hello there fellow zoners,
I am completey new to the zone and just brought my first E30 IS and well happy with it. Just brought my first mod a 3.91 LSD but has a lot of surface rust was wondering what is best to clean that nasty stuff off with?
Many thanks
mike :cool:
Post Sat Jun 28, 2008 11:17 pm
You could try a wire brush then Jenolite rust remover, then some black paint. Alternatively, you could leave it to soak in Malt vinegar overnight (you can buy in bulk cheap from Tescos, etc.) which is surprisingly effective at removing the worst of the rust. Oh, and welcome to the Zone! :)
E30ISMIKE
Post Sat Jun 28, 2008 11:19 pm
Thank you very much speedtoch im a complete blonde when it comes to this stuff :mad:
Post Sat Jun 28, 2008 11:22 pm
Blondes have more fun...you should see what we get up to with a few litres of Malt vinegar winkeye
E30ISMIKE
Post Sat Jun 28, 2008 11:30 pm
lol could just imagine so which do you think is most effective and with using malt vinegar would i fill it up to the top just below the breather pipe?
Post Sat Jun 28, 2008 11:35 pm
Not sure Mike, I've personally only ever tried this with a pair of brake calipers and it worked quite well, but some on here have dipped alsorts in a bath of vinegar overnight with stunning results. I guess if you intend to renew the LSD oil anyway, it doesn't matter if some gets inside...
E30ISMIKE
Post Sat Jun 28, 2008 11:41 pm
Yeah mate needs oil change not much in there anyways will find out some more info on this to see if it will be to give a bath overnight if not then will use wire brush method. Thanks for your welcoming really appreciate the info too speedtouch top lad will let you know what happens hpefully tomorrow
Post Sat Jun 28, 2008 11:44 pm
Be sure to refill with the correct LSD oil and NOT normal axle oil, which will kill your LSD's clutches :!:
E30ISMIKE
Post Sat Jun 28, 2008 11:47 pm
yeah was told by the guy i brought the lsd off what would oil you recommend i use?
Post Sun Jun 29, 2008 9:18 am
I'd go for some of BMW's finest if you can, but any appropriate LSD oil will do - try a search on here for recommendations.
JazzMan
Post Sun Jun 29, 2008 9:25 am
E30ISMIKE wrote:yeah was told by the guy i brought the lsd off what would oil you recommend i use?
Castrol SAF-XJ works very well in my LSD:
Chris-W
Castrol SAF-XJ or B373.
Chris-W
Post Sun Jun 29, 2008 9:29 am
Oh, and must say I'd not be immersing a diff in vinegar, personally.
fuzzy
He who sleeps with "Gingers"
Post Sun Jun 29, 2008 9:51 am
ive just cleaned up my diff and used the old faithful chisel/hammer/wire brush/elbow grease method. took me a good day to get it all nice clean and black hammerited.
stonesie
Post Sun Jun 29, 2008 4:15 pm
Maby this stuff would be worth a try, im going to get some to tackle the rusty sill on the turd im trying to sell :wink:
http://www.bilthamber.com/deoxgel.html
JazzMan
Post Sun Jun 29, 2008 4:19 pm
When I cleaned mine up I started with degreaser to get the gunge off then went over it with a hard wire brush and then a drill and wire brush attachment.
It should look something like this after a clean up:
After that I used some POR15 to cover it but hammerite should do the trick too.
