refurbishing bbs wheel's diy
david106
Thu Oct 26, 2006 1:08 pm
Has anyone had a go at doing it yourself , I've got a set which are ok they just need a repaint .
Grantley
Sun Oct 29, 2006 4:36 pm
I've just finished rubbing down a set of 5 BBS's by hand and my mate is etch priming and then painting them for me and while I'm looking forward to getting them finished and the feeling of satisfaction knowing that I did some of the work myself I'm never doing it again, ever :mad:
tobias
Sun Oct 29, 2006 9:05 pm
as above but only half way through and already cursing the day i started :cry:
Sooty
Sun Oct 29, 2006 9:31 pm
I started on the first one of a set a few days ago.
Anyone know how long it takes to grow fingerprints back......?
:surrender: :cens:
tobias
Sun Oct 29, 2006 9:41 pm
is anyone working on 17 inch splits???
jonbuoy
Sun Oct 29, 2006 10:01 pm
I did all 5 of mine.....
Cleaned them up with celilose thinner's with an old tooth brush, took a very painstackingly long time :cry: ...
Sprayed them with thick primer paint, light sand back with 600 wet'n'dry.
Haven't got a photo of when i covered the centre and painted the rim for some un-none reason :? but here's the other's.......4 of the wheel's are sprayed with paint from the local AutoCare :D
And the finished article after laquer :mrgreen:
tobias
Sun Oct 29, 2006 10:03 pm
nice 8)
reddevil
Sun Oct 29, 2006 10:09 pm
They look amazing Mate, do you proud.
Red D
1991 (H) 318iS Diamond Black, M-tech II spoiler.
K&N Panel filter-Viper2 chip-Zone BBTB
XBOX LIVE - reddevil1976
geo1400
Fri Nov 03, 2006 9:04 am
They look awesome mate! wish I had the patience...
Grantley
Mon Nov 06, 2006 6:52 pm
They look really nice mate, well worth loosing your fingerprints for a few weeks to get a finish like that :mad:
muleskinner
Tue Nov 07, 2006 10:06 pm
easiest way.... get em shot blasted or acid dipped to remove old paint , then powder coat em....trust me , with all the time and money you would spend on paint etc , the above will cost you about Ԛ£25.00 per wheel.
cheers
mule
SHAZ325iSPORT
Tue Nov 07, 2006 10:15 pm
i done these my self aswell,check out before and after!
these are 16" BBS 8J all round,for sale aswell if anyone intrested!
FROM THIS-
TO THIS-
cliffybabe
Powered by Nelly
Powered by Nelly
Wed Nov 08, 2006 12:49 am
Shaz what did u use to achive that polished lip?? they look fat as
SHAZ325iSPORT
Wed Nov 08, 2006 11:01 am
well the alloys were kurbed,so i grinder out,put a sanding disc on and sanded em down ,then got wet & dry and then used autosol.
Morat
Thu Nov 09, 2006 11:23 am
muleskinner wrote:easiest way.... get em shot blasted or acid dipped to remove old paint , then powder coat em....trust me , with all the time and money you would spend on paint etc , the above will cost you about Ԛ£25.00 per wheel.
cheers
mule
Have you got any pics of powdercoated BBS? I know someone who does powder coating professionally but I'm not sure it would look right on alloys?
edit: what about white powder coating to go with my white touring? :)
Rik178m
Thu Jan 24, 2008 7:40 pm
Which paint do you use for silver?
Can you do this with spray cans and how long will it last?
What laquer do you use?
arcdef
Thu Jan 24, 2008 7:52 pm
Rik178m
Thu Jan 24, 2008 8:14 pm
Cheers Sounds like a plan! winkeye
agreen
Thu Jan 24, 2008 10:02 pm
what sander was this are they on ebay ?
Chris
Sun Feb 17, 2008 12:14 am
Angle grinder with a sanding flap disc.
Removes Aluminium very quickly though so be careful.
