parksie wrote:Hi Jon & thanks for your interest, I wash the car as you discribe,then
1 coat Zaino Nr 5 as instructed then
1 coat Zaino Nr 2 "" "" "" ""
2 coats Zaino nr2 but with the accelerator added,.
Granted it has a good shine, but nothing like yours or indeed any better than my other polishes like Zymol, maguires, or autoglym.
If my approach with Zaino is not as you would recomend, then please feel free to educate a numpty in the valeting game
regards Steve Parkes
hi ok
i see acouple of maybe problems
the paint you are applying to HAS TO BE totally wax and previous product free
so car needs to be washed in fairy liquid and dried really well
now depending on condition of paint/age etc you now have adecision
you either clay bar the car as you have no swirls etc etc or you remove marks /swirls etc with appropriate products
once as good as you want it and remember PREP IS THE KEY,then begin to apply
but iam slightly worried about how you have only applied z2 with accelerator after 2 previous coats of zaino
1 of z5 and one z2
i have used z5 and its good but its meant to fill swirls to some extent instead of removing
it works well but not imho as well as removing altogether
i would
apply first coat of z2 on top of your totally clean paint but THIS MUST HAS HAVE THE ACCELERATOR ADDED
your first coat must use this or a precoat of Z1
i prefer the precoat of z1 as when i started using zaino zfx(accelerator) wasnt available
z1 is appliede very thinly and z2 is applied directly on top and you dont leave it to dry b4 the z2
you must let the z2 dry
this is all dependant on atmospherics,heat hunidity etc but my advice if you are applying by hand is to leave an hour
when u go to remove test by wiping finger on polish
if it comes straight off and leaves crystal paint then its ready if it kinda smears then its not ready
i apply with porter so its slightly different for drying because the porter applys such a thin coat it dries quicker and a little bit of heat generated by pad helps the curing
once you have taken this off leave car for at least 24 hours b4 applying any more polish
your car will look better in morning as it cures
you can apply a spray mist of z6 or now i use z8 tho its pricey and wipe off as u do it
i always z6/z8 between coats as it gives more depth without doubt
then i just build on it
i never (after 1st application) apply more than 2 coats in 24 hours
i get better results like that
i always give a little sprayof z6/z8 on what ever iam using to apply polish it just seems to help process
with zaino less is best
apply it as thin as you can.
follow this andiam sure you will see a difference
the first coat with accelerator or using z1 is the most important
john
