can anyone help with ice problems!
bigsmoke6368
Post Mon Apr 21, 2008 12:44 am
i recently bought a 325i se 4 door & lovin it!.......but when i turn up the choons the head unit knocks off.
its runnin 2 big door speakers and 2 big shelf speakers
i dont see no amp is that the problem?
ps i know nothin about sound systems and little about electrics.
can anyone put me on the right track? :mad:
blackBM
Post Mon Apr 21, 2008 8:35 am
hi im new on here but know a small amount about sound systems! to my knowledge that sounds like a bad earth on the sterio. is it only when turned up loud?
zaust
Zone day release
Post Mon Apr 21, 2008 4:11 pm
Check for cross (shorted together) wire's.
But most likely the stereo is clipping due to having a tiny built in amp.
Buy a better raido or a seprate amp.
M30 Tech 1 Touring on gas.
georob
Post Mon Apr 21, 2008 4:18 pm
Yeah, sounds like the h/u is autocutting out.
Amp the system or get a better h/u bud
bigsmoke6368
Post Mon Apr 21, 2008 7:43 pm
thanks lads! :thumb:
i should have a big chuffin amp and sub box in the loft somewhere i'd better leave it to the pros cause i'll probly end up with a charred mess on the drive where my e30 sits.
it only happened when turned up loud but you could still turn it back down and it comes back on again.
thanks again fellas!
325i se 4 door
mk1 2.0 escort mexico rep
mk3 cortina 4 door (resto project)
mrLEE30
Post Tue Apr 22, 2008 5:16 pm
if it as as you say in the last post i would say it is the potentiometer that controls the volume thats partially broken - is the volume knob a turn type or an electronic (i.e a button from up and a button for down)
bigsmoke6368
Post Tue Apr 22, 2008 9:19 pm
its a jvc cd head unit with a electronic up & down button.
would i be best to get a new head unit and put the amp and sub box in anyway?
325i se 4 door
kam325itouring
Post Tue Apr 22, 2008 9:21 pm
its either a earth prob or power prob.. my suggestion is run a new earth and new power to the battery, basically the original wires are not man enough to do the job for these new modern radios. The radio is not a alpine or kenwood by any chance??? I have experienced this before and doing what i said solved the prob, give it a go.
kam
kam325itouring
Post Tue Apr 22, 2008 9:23 pm
dont change the unit try the power and earth first..
blackjack
Post Wed Apr 23, 2008 1:53 pm
its either a bad earth OR you have a half dead speaker¬ when a speaker is clipped to hell the ohmage eventually drops where the coils start to die,,, once th eohmage has dropped too low it pulls too much current through the head unit therefore cutting out the head unit and setting it into auto protect!
bigsmoke6368
Post Wed Apr 23, 2008 6:48 pm
i thought it was a jvc but its not.
its a pioneer deh-535r 4x40wats powering 2 infinitys on rear and 2 audioscape in the door
i have no idea about the speaker power there is nothing on them to say.
i will try a rewire and keep you all posted !
thanks! :thumb:
325i se 4 door
