JBL GTO-4000 4Channel Is It Any Good???
Post Wed Apr 02, 2008 9:56 pm
http://caraudiosecurity.com/shop/produc ... /1180.html
am after an amp to amp my new speakers im not after the best amp in the world but something to liven the speakers up a bit and give better quality
ive got kenwood 6x9 in rear and infinity components in the front ???
What Are your thoughts on it???
Is JBL Good???
secondtimelucky
Post Wed Apr 02, 2008 10:24 pm
Would be perfect to 'liven up' your main speakers dude, more than the head unit power and not too much that it blows the crap outta your speakers, JBL sound pretty good too as a bonus :D
Wanted: Any old component speakers, complete or separate parts, let me know what you got :D
Post Wed Apr 02, 2008 10:31 pm
secondtimelucky wrote:Would be perfect to 'liven up' your main speakers dude, more than the head unit power and not too much that it blows the crap outta your speakers, JBL sound pretty good too as a bonus :D
just ordered it from amazon :D
secondtimelucky
Post Wed Apr 02, 2008 10:35 pm
:thumb:
vendetta
Post Wed Apr 02, 2008 10:43 pm
jbl are a good budget amp but for a few clams more i would have gone for an alpine v12
Post Wed Apr 02, 2008 10:48 pm
bought a JBL4060 a few weeks ago, was about £90 I think. Sounds alright, does the job
Post Wed Apr 02, 2008 10:53 pm
would the amp be ok mounted verticlly, iirc some can overheat mounted like that :?
mrLEE30
Post Thu Apr 03, 2008 10:32 am
ideally amps should be mounted flat as the heat sinks are on the top, but if you mount it vertically it should not be too bad so long as there is enough free air in front of the thing to allow the heat to dissapate. with the GTO one you will see the heat sinks (they are the metal fins on each side of the ''window''). mount the thing so they are also vertical (i.e with the speaker wires either facing up or down, NOT to the side)
is that clear????
mrlee
Post Thu Apr 03, 2008 4:29 pm
mrLEE30 wrote:ideally amps should be mounted flat as the heat sinks are on the top, but if you mount it vertically it should not be too bad so long as there is enough free air in front of the thing to allow the heat to dissapate. with the GTO one you will see the heat sinks (they are the metal fins on each side of the ''window''). mount the thing so they are also vertical (i.e with the speaker wires either facing up or down, NOT to the side)
is that clear????
mrlee
cheers
Post Wed Apr 09, 2008 3:45 pm
fitted today well please it kicks out tons of BASS!!! :D
Need to sort wireing out tho
Any suggestions on how to secure it :?: screws, velcrow :?:
Post Wed Apr 09, 2008 3:48 pm
I forgot to put the inline fuse in that came with wireing kit :cry:
would it be ok without as there is some fuses in the actuall unit :?
Post Wed Apr 09, 2008 3:57 pm
better off installing the inline fuse from the battery live, you've probably seen the size of the fuse, they are massive and will stop any serious problems if you were to get a short in the power lead running through the car, which could cause a nasty fire if there is no fuse protection.
Post Wed Apr 09, 2008 3:58 pm
E30BeemerLad wrote:better off installing the inline fuse from the battery live, you've probably seen the size of the fuse, they are massive and will stop any serious problems if you were to get a short in the power lead running through the car, which could cause a nasty fire if there is no fuse protection.
thought so :D
tailoutcharlie
Post Thu Apr 10, 2008 12:10 pm
and get rid of the wafer thin speaker wire going to the rears, weakest link in the chain. never been a fan of scotch blocks either winkeye
Chris
Post Thu Apr 10, 2008 12:38 pm
tailoutcharlie wrote:and get rid of the wafer thin speaker wire going to the rears, weakest link in the chain. never been a fan of scotch blocks either winkeye
yer when i sort out the wireing etc i will take the scotch blocks off and put new wire in. i was just rushing to put it in near the end coz it was snowing :cry: sounds good :D
tailoutcharlie
Post Thu Apr 10, 2008 12:49 pm
oooh automotive electronics in the snow, sounds like fun 8O
amps can be such a pita. wish i stil had my saloon, at least the bat was in the back, sooooo much easier
Chris
Post Thu Apr 10, 2008 1:03 pm
tailoutcharlie wrote:oooh automotive electronics in the snow, sounds like fun 8O
it was lovely when i started
