intermitent crackle
markdemon
Post Tue Mar 25, 2008 5:49 pm
hi guys
just fitted my new infinty components in the car and there is a crackle cummin out occasionally on certain tracks when the volume is increased to number 35(headunit goes up to 40)is this just 2 much output from the head unit for the speakers to handle or have i trapped a cable and its grounding out on the car.
hope someone can explain this to me
cheers :)
Pyros
Post Wed Mar 26, 2008 9:48 am
on the tracks that crackle is there much difference between them and other tacks ie. more bass?
chu346
Post Wed Mar 26, 2008 11:53 am
How much of a crackle?
Are the cd's copies or original?
markdemon
Post Wed Mar 26, 2008 2:02 pm
there is some slight differences in bass yes and there copies not orinal cd's it can be very sudden then nothing then again,so its not all the time and not on every track.
Post Wed Mar 26, 2008 5:55 pm
it might be coz yo uhave the headunit turned up too much you might need to amp them if you want LOUD
maxfield
Post Wed Mar 26, 2008 6:15 pm
Could be the way the cable is routed, my dad had this until he re routed all his cables.
markdemon
Post Wed Mar 26, 2008 6:50 pm
i cant route them any other way as there goin into the doors, it looks like aan amp like u say alex
cheers
Post Wed Mar 26, 2008 7:01 pm
markdemon wrote:i cant route them any other way as there goin into the doors, it looks like aan amp like u say alex
cheers
yer you might be best doing that, if you have your head unit at 35 vol when max is 40 you obviosly like your music loud so an amp would make a huge difference
markdemon
Post Wed Mar 26, 2008 7:08 pm
yeah ive got a 650w amp just sat here so its goin in at the weekend ill keep ya informed as to the cure :)
chu346
Post Thu Mar 27, 2008 9:01 am
markdemon wrote:ive got a 650w amp
That don't sound good 8O
Upgrade your power and earth to the headunit and make sure your using some proper speaker wire not the same kind as you wire a door bell with.
BTW what headunit is it?
Pyros
Post Thu Mar 27, 2008 9:56 am
as chu346 said make sure you are using proper speaker cable and not stock cable thats in the car as it brings the quality down
markdemon
Post Thu Mar 27, 2008 8:21 pm
its the best u can get guys i never scrimp on my cabling when it comes too my sound systems,its a jvc system old but ok i think but im gonna try my sony headunit in it at the weekend :)
