where/how can I get a power lead from the battery under the
snoops
Major Helmet
Post Mon Mar 24, 2008 11:23 pm
where/how can I get a power lead from the battery under the bonnet to my stereo?
tia
cliffybabe
Powered by Nelly
Powered by Nelly
Post Mon Mar 24, 2008 11:44 pm
u mena u want a constant power for the radio live??
maxfield
Post Mon Mar 24, 2008 11:54 pm
For a constant live I took one from the cigarette lighter.
snoops
Major Helmet
Post Tue Mar 25, 2008 12:06 am
no I mean how can I connect the power lead from my amp in the boot to the battery? will it fit through the grommet behind the glovebox? any tips on how to get it through?
cliffybabe
Powered by Nelly
Powered by Nelly
Post Tue Mar 25, 2008 12:11 am
yeah it will go throught he gromet make a small hole in the gromet stick a coat hange rthrought he hole look under th edash find ur metal coat hanger get some leccy tape and tape the wire to the coat hanger and pull it through :thumb:
snoops
Major Helmet
Post Tue Mar 25, 2008 12:14 am
thanks :thumb:
cliffybabe
Powered by Nelly
Powered by Nelly
Post Tue Mar 25, 2008 12:17 am
no worries god luck remember to run the rca's away from the battery cable cos it can cause distortion :cool:
snoops
Major Helmet
Post Tue Mar 25, 2008 12:30 am
will do, what will happen if I connected the subwoofer wrong (i.e. got + & - mixed up) as I connected the terminals of the sub to the wires without checking, I know you can check by using a battery and checking to see if the speaker pops out or in but I don't really want to have to disconnect everything and open up the sub box to check
would it cause any damage
cliffybabe
Powered by Nelly
Powered by Nelly
Post Tue Mar 25, 2008 12:38 am
i'd check cos it can send the audio signal in squares rather than waves causing the sub to burn out on the wire that runs the subs coil for the 6-8screws to release the sub its worth it to be on the safe side
I would even do the battery trick, I dont rate that at all
tomtomiS
Post Fri Apr 04, 2008 11:54 pm
maxfield wrote:For a constant live I took one from the cigarette lighter.
mind those stirrups max, thats the worst piece of advice you have ever given, and if ur using the same method on your car you really should do it properly
ian332isport
Post Sat Apr 05, 2008 9:54 am
My God ! There's a lot of dodgy info in this thread 8O
Swapping the connections to any speaker will not cause any damage to the speaker (sub or otherwise), or the amplifier. It can however effect how the system sounds overall.
If one speaker is pushed outwards, at the same time as another speaker is going inwards, the sound waves can effectively cancel each other out. It's not quite so important with a sub, as the frequencies involved are a lot different to the rest of the speakers in the car. It would be a big issue if you have more than one sub though.
Ian.
