8x17" wheels ET30 60/40 drop??? Is it possible?
Fal_325i
As per title guy's have a set of 8x17" alloy wheels, which will possibly be shod in 215/40/17 tyres, the car has a 60/40 drop, and the wheel offset is ET30, the arches are standard(not rolled), my question is: will I have issues with this setup?, will I require spacres or the wheels?, wheel std arches be upto the job?, many thanks
Fal_325i
Come on guy's, someone must know an answer to this.
deepak
these should fit without an issue, the front may require 5mm or 10 mm spacers. the e30 offset is meant to be 15 - 25. they will not rub and they should be fine with standard arches. hope this helps, any more info just ask.
Fal_325i
Cheers deepak, much apprecoated mate.
snoops
- Major Helmet
they should be about et 20
Fal_325i
so what do I do in order to make them fit?
cliffybabe
- Powered by Nelly
im running 17's with a et30 offset u need a 5mm spacers for lock to lock, think mine are 7 or 7.5 ill check if there 8inch wide u might need a 10mm spacers
Fal_325i
Cheers cliffy if you could check please.
