bigSuNnY
Post
Mon Feb 18, 2008 11:27 am
Hi just brought a e30 cab in white...
Not sure what size alloys it will take without all the nonsense of rubbing on the wheel arches etc etc..
Can any1 help.. i would prefer nice 17"
Bearing in mind this e30 has not been lowred.. Cheers guys
SUNNY
zaust
- Zone day release
- Location: Somewhere in Hertfordshire , or press Ctrl + W
Post
Mon Feb 18, 2008 4:52 pm
16 if you drive hard but 17's will go.
M30 Tech 1 Touring on gas.
bigSuNnY
Post
Tue Feb 19, 2008 9:02 am
cheers zaust
also what size tyres are recommended..?? thanks
zaust
- Zone day release
Post
Wed Feb 20, 2008 11:55 am
I run 225/40 16's.
80mm drop
d6dph
Post
Wed Feb 20, 2008 12:02 pm
I run 17's without an issue.
60/40 drop with 215/40/17's all round.
BadDave
Post
Wed Feb 20, 2008 8:06 pm
18's and even 19's have been fitted to the E30
Not many have fitted 19's
Can only think of player6 at the moment.
Other may know of more with them fitted
I've fitted 18's to the tourer without problems
They were fitted with 215/35/ZR 18 tyres
bigSuNnY
Post
Thu Feb 21, 2008 2:38 pm
Does 60/40 mean u lowerd it 60mm on front and 40mm on the back D6DPH..???
No rubbing what so ever..??
Cheers for the info guys
Cotty
- Hartge Crew
Post
Thu Feb 21, 2008 5:50 pm
60/40 usually refers to dropping the front 60mm and the rear 40mm
bigSuNnY
Post
Thu Feb 21, 2008 6:07 pm
How come you have only done 40mm on the back..?? are the rear aloys bigger or sumet..?? i cant understand why 2different drops.. cheers
BadgerSi
Post
Thu Feb 21, 2008 6:43 pm
Raking the vehicle so the front is lower then the back will increase vacuum due the the pressure change of the air passing under the vehicle and help road holding.
Cotty
- Hartge Crew
Post
Thu Feb 21, 2008 6:50 pm
There is a bigger gap between the front tyre and the arch compared with the back.
This is mine with standard ride height. The car sits level but look at the front tyre to arch gap
This is lowered 60/40. see the gap is now even front to back
BadgerSi
gooner1
- Out humping Reindeer
Post
Thu Feb 21, 2008 7:02 pm
Does,nt that depend on the year of the cab though, are,nt pre facelift arches slightly different .
Or am i talking out my arch again
elf
Post
Thu Feb 21, 2008 7:22 pm
BadDave wrote:18's and even 19's have been fitted to the E30
20,s on mine must be a first.
previously i had 18 with 235 35 tyre
30/35 drop no probs just 6mm spacer on front.
depends also on what wheel you get and offset
d6dph
Post
Thu Feb 21, 2008 7:55 pm
bigSuNnY wrote:I run 17's without an issue.
Hi mate,
I don't like cars that are lowered 60mm all round, Looks like a dog dragging its arse along the ground.
60mm f & 40mm r gives just a nice stance imo.
No rubbing now, I played around with spacer widths to get the wheels to sit nicely in the arch and not foul. Occasionally I get a little scrub on lock going up bumps but that is really rare.
blingsta
- Boost Junkie
Post
Thu Feb 21, 2008 9:39 pm
18's on mine at standard height with 215/35 tyres... no issues..
1an
Post
Thu Feb 21, 2008 11:16 pm
60/60 on my car
but as the back half is all stripped out etc sits more like 60/50 which is alright
1an
Post
Thu Feb 21, 2008 11:33 pm
1an wrote:60/60 on my car 205/55/25 tyres though
bigSuNnY
Post
Fri Feb 22, 2008 9:04 am
Cheers for all the info guys..
I will be lowering mine 60 f and 40 rear... thanks again
suzie650
Post
Fri Feb 22, 2008 2:42 pm
BadgerSi wrote:Raking the vehicle so the front is lower then the back will increase vacuum due the the pressure change of the air passing under the vehicle and help road holding.
Simon, you creep!
Seb
BadgerSi
Post
Fri Feb 22, 2008 7:03 pm
[/quote]Simon, you creep!
Seb[/quote]
