Cheap Ebay Car amps
E30Mark
Please don't bump post after 45 minutes
And the old saying of you get what you pay for is so true!
PM for details
PM for details
- secondtimelucky
Depends on the price bud, i couldnt see one, dont spend more than £60-70 on one though, mutant do some sweet amps for this money and above. Dont believe the 400watt BS either, its peak power!!!!!
if its 2 channel then:
200watt/channel peak
100watt/channel RMS=about enough to run a decent set of 6x9s
if its 4 channel then:
100watt/channel peak
50watt/channel RMS= just enough to run front and rear components
HTH
HTH
Wanted: Any old component speakers, complete or separate parts, let me know what you got
cheers im going to spend 60-70 quid on upgrading audio as all speakers are the original bmw ones thinking about getting some tweeters do they make much difference?? going to keep current head unit tho as its fairly decent
I have a 2 channel amp if anyone wants???
Its a Rally 250watt I think? Works well for the money.
Regards
Clyde
Go everywhere sideways...
Clyde
- secondtimelucky
clubfx2: ul get in trouble selling ur amp on here mate
Alex: What head unit do you have?? are you doing a big system or just head unit, amp, and speakers?? more info needed to be able to help
tweeters will make a difference but not really6 worth it on their own bud, get some components up front (13cm bass cones and separate tweeters) and some coaxials (13cm bass cone with tweeter integrated) in the back, that would be a good first step mate
Just an offer as its no use to me.
Have it sitting in a cupboard collecting dust.
Regards
Clyde
Clyde
personally i wouldnt be buying one of those amps,
dont go by any of the power figures, spend as much as you can on each part of the system, like satying do you really need to indvidually am the speakers or could you spend abit more and get a better quality headunit?
i did my girlfiriends car with consited of 13cm mtx thunder components up front and some 13cm mbquartz co-axle speakers out back. this is all being run of the headunit which is a 200 alpine headunit and it will give alot of stereo's in alot of car stereos where people spend twice as much as we did on her car.
my car runs the same speakers except i have the top Alpine headunit in my car and the differnce is amazing. but i want to go louder and cleaer so im going to be getting myself a decent quality 4 channel amp. you will find that the more you spend the lower the power ratings, but as i said earlyer big power figures dont mean alot.
- secondtimelucky
clubfx2: no worries bud, just letting you know, i did the same thing a while back, the post got removed and i had a quiet word from the mods
i think i will end up getting some tweeter pods and puting some of these in
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... :IT&ih=017
and getting some of these for the back
http://cgi.ebay.co.uk/Kenwood-KFC-1360S ... dZViewItem
ive got a kenwood headunit saying its only a few years old it probly about 6 year old but it seems fairly good its power output is 45w
basically i just want clearer and louder sound and slightly more bass
hongkongfuey
- Mad-tango-geezer
i got infinity 3 way 100w rms 6x9 in the rear, they were run on 2x 80 rms mutant amp which i still have
now i'm running on a 4 way splx amp, focal front components in a door pod + jbl's in the kick pannel
with cars like mine,
A better option would be a set of 2 way components(5 1/4" or 13cms) for the front with the tweeters mounted in the original tweeter pods and the mid/mid bass drivers in the footwells,then worry about what to fit in the rear.
Thats a good plan could you advise me of any good 2 way components for the front can you get any good ones around the £40 pound mark
seen these but not sure if the tweeters would fit in the tweeter pods
http://cgi.ebay.co.uk/Kenwood-KFCP522-1 ... otohosting
BadDave
Before you spend any money on the speakers,head down to your local car audio specialists,(even,dare i say it,Halfrauds) don't just go to 1,have a chat with as many as you can, preferably 2 or 3, more is better and ask there advice and listen to the speakers on there demo stands
Even better if they have a demo car or 2
Sit in them and have a listen to there systems(probably hi end set-ups) but it'll give you an idea of what'll sound good and what won't
Let you ears decide what's best for your budget
Tweeter pods are a good starting point and so would be the MB Quart tweets you mentioned
Just make sure you have a high pass filter in-line to the tweeters.
BadDave
Hads a look at the Kenwoods comps and i'm guessing the tweets might be a bit big to fit in the tweeter pods
They could,however be surface mounted onto the original flat black plastic mirror blanking plates,either screwed,bolted,superglued or siliconed
I still reckon it would be bestter to listen to several setups 1st before handing over £Â£Ã‚£Ã‚£Ã‚£ for your speakers
- secondtimelucky
It does that sometimes, usually a sunday too
yer i will probly go to halfords and see what they got just found theseI still reckon it would be bestter to listen to several setups 1st before handing over £Â£Ã‚£Ã‚£Ã‚£ for your speakers
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... PIC&ih=002
im sure last time i was in halfords they had a set of these so might go down sometime and have a listen
hongkongfuey
- Mad-tango-geezer
where are you in the world if you are near portsmouth you can listen to mine?
BadDave
I'm sure there are some other pretty good ones near the £40-£50 markAlex wrote: Thats a good plan could you advise me of any good 2 way components for the front can you get any good ones around the £40 pound mark
However, I'm unable to comment on these at this time(without actually hearing them) as i've been using the same MB Quart and Alpine speakers for years, coz I like them.
However,I shall be introducing some old skool RF mids and infinity tweeters into my system at some point later in the year.
In your position and budget, I'd be inclined to stick with the more mainstream brands eg Kenwood/Alpine/Sony/MB Quart/ and possibly Vibe(they have some nice 2 way comps for about £50 with kevlar cones at the mo)
BadDave
Your more than welcome too come up and listen to mine if you'd like
MB Quart subs in the front doors with tweets in the original tweeter pods and old skool alpine mids in the footwells
MB mids& tweets in the rear enclosures(it is a touring after all)
Alpine 12" subs x2
with
Alpine pro logic processor with built in 1/3rd octave parametric EQ/time correction/dolby surround sound
Just needs a centre channel
Heres a link to the Vibe's i mentioned
http://cgi.ebay.co.uk/Vibe-SE-K-Series- ... dZViewItem
Alpine 12" subs x2
with
Are you going to put a big sup in in the future ? if you are then you wasnt as mentioned on here decent front speakers with seperate tweeters and some 5 1/4 ones with built in tweeters in the rear but if you are going to stay without an amp just get some decent 6x9s in the rear if you get some decent ones they will be bassy enough
i had 2x 100w Infinity 6x9s in the back of my old capri along with some 5x4 speakers in the door cards (to fit behind standard grills) first off i had them all running off the headunit and the sound was fairly good sony headunit with 4x50w rms outputs but then i put a 2x 80w rms amp in to run the 6x9s and the sound was really good deffinately loud enough (even over a completely straight through exhaust system)
i think the 6x9s were about £50 in a sale and i got the amp free lol
ian332isport
- Contact:
Guys,
I've had a bit of a tidy up on this thread. Not sure what happened there. Looks like the zone had a brain fart or something
Ian.
Ian.
First off, don't buy any of the unbranded cheap amps from ebay or anywhere else. You'd be better off with something 2nd hand. You can pick up a nice 2x50w rms apline, kenwood, JBL etc for £20 - £40, and it will knock the socks off those chinese cheap amps.
BTW, those amps claim 400w, but only have a 5A fuse! Using generic figures, and 14.4v input, the actual power is about 21w rms per channel - and that's being generous. Probably no better than headunit power.
This is what's inside them:
As for comps, I haven't heard a huge selection recently, but these are quite often recommended as good value on other ice forums:
http://www.caraudiodirect.co.uk/dynamic ... -5522.html
Hope that helps.
Hope that helps.
