radio problem !!!
onlyme
Post Sat Jan 12, 2008 4:39 pm
The radio in my 320 will not keep its preset radio stations after the ignition has been turned off and then back on,any help is much appreciated
secondtimelucky
Post Sat Jan 12, 2008 6:27 pm
constant live and ignition switched live are the wrong way around :D
Wanted: Any old component speakers, complete or separate parts, let me know what you got :D
maxfield
Post Sat Jan 12, 2008 6:28 pm
Your live could be dead.
It was like this on my car.
A feed from the battery sorted it though.
secondtimelucky
Post Sat Jan 12, 2008 6:40 pm
^^^^^most head units wont work with just a switched live bud :mad:
maxfield
Post Sat Jan 12, 2008 8:24 pm
I said that wrong, I used the live feed from the cigarette lighter.
toby
Post Sun Jan 13, 2008 3:42 pm
maxfield wrote:I said that wrong, I used the live feed from the cigarette lighter.
Why?
That isn't a suitable circuit - to high a fuse rating!
Mr onlyme, your radio should have a constant 12V supply and one that switches off with the ignition. It sounds as if the constant 12v suppoy is missing from what you wrote. Get a test light and check it out.
Cook318IS
Post Sun Jan 13, 2008 3:45 pm
sounds like secondtimelucky's spot on. i used to work at halfords and if that happend after we fit a stereo, jus switch the two wires around!
tari
Post Mon Jan 14, 2008 12:35 am
i agree with this one 100%, as the stereo need both constant and ignition to come on
onlyme
Post Tue Jan 15, 2008 5:37 pm
onlyme wrote:The radio in my 320 will not keep its preset radio stations after the ignition has been turned off and then back on,any help is much appreciated
thanks everybody for your advice and help,have got it sorted by a local audio shop!!
