Mini wheels????
raulandthetwins
Post Thu Jan 10, 2008 11:28 pm
Does anybody know if you can fit new mini wheels to an e30? i understand bolt pattern is 4x100, but what about offset etc?
bodger
Post Thu Jan 10, 2008 11:40 pm
i am also interested about this, im sure its been mentioned before and the offset is wrong so spacers are need, someone with more intelligence will come along soon
1an
Post Thu Jan 10, 2008 11:42 pm
need to run 10mm spacers i believe.
BadDave
Post Fri Jan 11, 2008 6:33 pm
IIRC the offset on the 17" m ini rims are 38 or 40mm so spacer would be required
Both my 16's and 18's have a 40 mm offset and i use a 30mm spacer with them (that's to clear my brake calipers)
You'd probably only need a 15-25 mm spacer and a different spigot ring
BadDave
Post Sat Jan 12, 2008 2:35 pm
Have since found out that the mini wheels have the same 57.1mm centre bore and normally have a 35mm offset
HTH
Dave
