Tweeter pods
Moz
Post Fri Jan 04, 2008 2:21 pm
Finally got the tweeter for my pods. I removed the old nokia tweeters, magnet first, then the plastic ring with waterpump type pliars. Photos below, tweeters are MB Quart DTD19 and fit very well, ill be sealing the edges with black silicone so they are secure.
More pictures of the entire install coming soon.
Moz
zaust
Zone day release
Post Fri Jan 04, 2008 5:50 pm
Good work fella.
Keep em comming.
M30 Tech 1 Touring on gas.
Moz
Post Fri Jan 04, 2008 6:33 pm
Thanks, will post the full install pics when I have a proper headunit. My Nakamichi has died so looking for a replacement for my temporary Kenwood cassette MASK.
Moz
Post Sun Jan 13, 2008 6:04 pm
have you tested them yet? whats the sound quality like because im looking at getting a set of ebay :D
Moz
Post Wed Jan 16, 2008 4:36 pm
Id say hardly noticeable at the moment but dont quote me till ive tested them using the Nakamichi 1000TD.
Moz
zaust
Zone day release
Post Wed Jan 16, 2008 6:12 pm
Are you running them with a cross over.. ??? Also these tweeters like a bit of power through them.
Moz
Post Thu Jan 17, 2008 1:07 am
Yes, tried them with both the MB Quart ones but am using some old school panasonic ones. Amp is a small sony xm-2540s.
Moz
terryphelan
Post Fri Mar 06, 2009 12:11 pm
Hi Moz, just about to do the same thing as yourself, how did you get the old tweeters out? I don't want to use too much force as the pods are pretty delicate. Thanks
guizai
Post Fri Mar 06, 2009 6:14 pm
Can you speak more on the crossovers you're using and how you wired them up? I need a set for my tweeters and I'm not sure what to use. Thanks!
poolnoodle
Post Sat Mar 07, 2009 11:17 pm
terryphelan wrote:Hi Moz, just about to do the same thing as yourself, how did you get the old tweeters out? I don't want to use too much force as the pods are pretty delicate. Thanks
I used a small screwdriver to carefully prise out the magnet part (comes away relatively easily) then remove the grills to stop any damage (they just push out) and finally gripped the plastic ring part with needle nosed pliers and (again carefully) twisted slightly to break the glue seal and then with a little force they just pulled away. Worked a treat with no damage to pods.
Morat
Post Sun Mar 08, 2009 1:39 pm
Nice neat job, I've got the pods and the new tweeters waiting for the same treatment, once I get out of work for a minute :/
mineralblue
Rocking Horse Poo
Post Sun Mar 08, 2009 1:43 pm
I'm in the process of doing this myself.Got the old ones out, but my new ones are different in shape to the old ones and have no flat flange, so to speak to glue to the pod. Anyone come across this before and best methods of fixing them in?
Post Sun Mar 08, 2009 4:29 pm
mineralblue wrote:I'm in the process of doing this myself.Got the old ones out, but my new ones are different in shape to the old ones and have no flat flange, so to speak to glue to the pod. Anyone come across this before and best methods of fixing them in?
i used a tiny bit of super glue to hold them in place, then used silocone :D
robbo86
Post Sun Mar 08, 2009 7:59 pm
Where did you locate your crossovers?
Post Sun Mar 08, 2009 8:26 pm
robbo86 wrote:Where did you locate your crossovers?
i put one of mine above the speaker in the drivers footwell where there is an indent and the passanger side is the same i think.
