FRONT ARM RESTS.
ed325i
Post Thu Jan 20, 2005 12:23 pm
HI, I have got a couple of E32 front arm rests that I am going to fit in the front of my cab. I was wondering if any one has done this and could offer some advice on the fitting.
325i-sport
Post Thu Jan 20, 2005 1:06 pm
are the rests similar to the e30 ones? if so I can help you. post a pic of it so i can see. cheers
ed325i
Post Thu Jan 20, 2005 1:27 pm
Don't know if they are like the e30 ones. The ones I have bolt on to the seat with 2 bolts and there is a button on the end which you press so you can move it up and down. i have no camera at the mo
Lizzie
Retired Admin.
Post Fri Jan 21, 2005 1:59 am
Are you talking about the thin narrow ones that you can tilt to two different angles. The depress button is at the front of the armrest?
I suppose it all depends upon the fitting brackets I would have thought.
Alpine White II 1990 E30 325i Auto Conv
ed325i
Post Fri Jan 21, 2005 10:33 am
what I would like to know is the hight that they are fitted. yes they are the thin ones with the button on the end.
Cloggy Saint
Post Fri Jan 21, 2005 6:15 pm
I may be wrong but i think that there are mounting points on the frames of all E30 seats. If you remove the seat back you should be able to see if they are there or not. If they are it's just a case of drilling the holes through.
tari
Post Sun Nov 26, 2006 7:12 pm
u need to drill em!
test the height b4 cos u dont want a holy seat
