Touring ICE
maxfield
Post Thu Dec 06, 2007 6:17 pm
Just looking for a little of advice on ICE for a Touring.
I will be looking to build in a false floor in the Touring so the ICE is out of sight, I live in a rather rough area!
Obviously I'll need cooling for the amp, but that's not a problem.
But what about subs and amp, as these will need to be small as I don't want to lose much space.
What about up front?
And not looking to spend loads either...
Jamie.
jamesc
Post Thu Dec 06, 2007 6:44 pm
I put my amp and crossovers in the storage bin behind the drivers side rear wheel......
James
blackjack
Post Thu Dec 06, 2007 6:53 pm
u can get a pair of CDT 8" components for around 200, give them 250wrms each in about 0.75 cubic ft box each and they will punch harder than most 10" subs each! then put the tweeters that come with them in the back somewhere directed towards the front
up front u could use the cdt shallow coaxils if you dont want to cut anything up front!
whats ya budget, will make life a hell of a lot easier!
Heyho
Post Thu Dec 06, 2007 6:55 pm
I'll be putting a system together in my touring over the next few months hopefully.
The intention is a custom sub build in one side of the boot (in storage area), and the amps in the other side. Should be pretty stealthy.
For the front, a decent set of 5.25 comps, maybe 6.5s if I can be bothered with the work!
maxfield
Post Thu Dec 06, 2007 6:58 pm
Looking for eBay bargains TBH with you. :)
But around £100-150.
secondtimelucky
Post Thu Dec 06, 2007 7:19 pm
Get yourself something like this built:
and a load cover, the whole lot can be hidden under the cover for stealth.
the sub box stops just short of the hinges in the original floor, meaning when the (non-fixed) false floor is lifted, the amps and lighting all lift up too, giving easy access to the spare wheel as well :D . And the whole boot build has cost less than £250 so far
Heyho
Post Thu Dec 06, 2007 7:35 pm
maxfield wrote:Looking for eBay bargains TBH with you. :)
Do you have anything to start with - ie a headunit?
What sort of sound are you after? Do you want quality or volume?
Ebay is a very good start, but I do prefer to buy speakers new - as they can be fragile, and you don't know what sort of life they've had previously. Most of my amps are second hand from the bay!
maxfield
Post Thu Dec 06, 2007 7:44 pm
Yes, I have a headunit.
I would like to have a bit of both. Don't want it loud and sound shit, but don't want very good quality and not be very loud.
I would only want to be running one amp and 2 subs and whatever is needed up front.
secondtimelucky
Post Thu Dec 06, 2007 7:49 pm
Go for two amps mate, purely because of the position of the front speakers in an e30. they need power to help them sing, and one more as you said for your subs. I used to run my speakers off the head unit and it was ok but the difference an amp makes, even a small one, is staggering. Much better volume and quality too. You will hear details you didn't know existed :D even on stock speakers, as i did first time round, and they took 80 watts RMS up each of them :mad: sounded pretty good actually :o:
Heyho
Post Thu Dec 06, 2007 8:40 pm
As secondtimelucky says, even stock speakers can sound surprising - internal headunit amps are never particularly good for SQ.
Given your budget, I'd go for a set of component speakers up front, and a single sub in the back. Power this lot from a 4-channel amp, with the comps on 1+2, and 3+4 bridged for the sub. The cheapest new amp that outputs enough for such a system is probably something like a JBL 75.4 - about £100 new delivered, but keep an eye out for something 2nd hand.
Something like this would do:
http://cgi.ebay.co.uk/infinity-amplifie ... dZViewItem
Although it's infinity, it's made by JBL - they are the same company, just a bit of badge engineering - like VW/Skoda ets.
Same goes for subs - there are loads of JBL GT4 10" or 12" out there new from about £30 - but you'll need an enclosure and wiring kit etc - it all mounts up. I have a GT4 12 in my golf at the moment - sound quality is good, and I have the ability to rattle the interior if necessary.
maxfield
Post Thu Dec 06, 2007 8:43 pm
Thanks for the advice.
Much appreciated.
secondtimelucky
Post Thu Dec 06, 2007 8:44 pm
!!!Never knew that!!! JBL and Infinity??? Same company(ish) well il be dammed :mad: always rated infinity much higher than JBL
BadDave
Post Fri Dec 07, 2007 9:14 pm
Some of my work in progress
No issues with the amps getting to hot
There is now a 3 section false floor on top of the amp/crossovers/distribution blocks now
blackjack
Post Fri Dec 07, 2007 9:50 pm
secondtimelucky wrote:!!!Never knew that!!! JBL and Infinity??? Same company(ish) well il be dammed :mad: always rated infinity much higher than JBL
WRONG they are not the same company - they have the same uk distributor!
although a few sets of the earlier 6x9s and coaxils were made by the same factory in south africa then badged to suit each company!
same as audiobahn and alphasonik share the same postal adress, its due to the distribution companies!
scariest one though is pro-plus and sony are the same ;) 80 quid difference in the cost of the subs"
jbl is far superior to infinity! if ya know how to use it proper ;)
Heyho
Post Fri Dec 07, 2007 9:51 pm
Fook me BadDave, that's a fair amount of gear you've crammed in there - almost room for the shopping as well!
Is that an Autotek 5-way active X-over?
blackjack
Post Fri Dec 07, 2007 9:59 pm
Heyho wrote:Fook me BadDave, that's a fair amount of gear you've crammed in there - almost room for the shopping as well!
naaa this is crammed in ;)
(4 amps - 2 on top of 2, around 12(ish) batteries, line driver, charger input, multimeter, lightbulbs to regulate voltage after charging, and head unit!
BadDave
Post Fri Dec 07, 2007 10:08 pm
No
It's a Pro sound 3/4/5 way x over
My 6 channel Kenwood got fried so needed a replacement and it came cheap and does the job
Sub cabinet was designed to house the 6ch amp for the fronts/sub amp and the dolby surround processer+EQ to give me some room in what was left of the boot area
Heyho
Post Sat Dec 08, 2007 8:53 am
BadDave wrote: It's a Pro sound 3/4/5 way x over
I think they are the same unit - I paid £17 for mine - turns out that they are actually pretty good. Only thing I'd like to be able to do is drop the HPF for my mids - the lowest it will go is 90hz, but I may go back to passive for my E30, mainly to simplify things.
rebelcruiser
Post Sat Dec 08, 2007 3:53 pm
looks good badDave :wink:
blackjack it looks crammed in because its a nova which is the same size
as a baked bean tin. winkeye
BadDave
Post Sat Dec 08, 2007 5:37 pm
I DO miss my 6 channel Kenwood but the Pro Sound does the job quite well
I'll have to change the rear(RTO) x-over to something more in keeping with the rest of the system components
I'm using 6 1/2" subs in the front door builds and feeding them with 80hz-400hz (used as sub and mid bass)with the mids getting 400hz -- about 1.2 khz and the tweets getting the rest.
My Alpine processor doesn't allow the fronts anything below 80hz if the subs in the rear are switched on but does if they're switched off
I use the paremetric EQ in the pro logic processor to boost/cut as required
Got the time correction about right as well,I think
Fairly makes a difference when playing a dvd
All it needs now is the centre channel aquired/fitted and trimmed to finish
blackjack
Post Sat Dec 08, 2007 11:39 pm
rebelcruiser wrote:looks good badDave :wink:
yep but 171.7 db's and the uk's loudest car ;)
rebelcruiser
Post Sun Dec 09, 2007 12:09 am
it may be the loudest but also the slowest
shane325i
Post Mon Dec 10, 2007 4:45 pm
This is/was my touring set up-
I made the box myself and will be selling it shortly as its no longer needed.It houses a set of 3 way componants and a 12"sub.Combined with the Infinity componants i was running up front its sounded fantastic,lots of bass but not too boomy!
