Seprarating Tech 1 Spoiler
Rkive
Post Mon Nov 05, 2007 2:26 pm
How do you separate the spoiler to spray?
FWD is for Pussy's
Ziggy
Post Mon Nov 05, 2007 2:29 pm
You can see the bolts from underneath :thumb: It got there ok then?
Rkive
Post Mon Nov 05, 2007 2:44 pm
Yeah came down fine, thanks again.
Do you mean the actual bolts with nuts on or the twisty things?
FWD is for Pussy's
Ziggy
Post Mon Nov 05, 2007 3:18 pm
From memory, you should be able to see a bolt head at either end? Not the 6 studs (with nuts loosely on em) that are for mounting to the bootlid. Not sure what you mean by 'twisty things', but I might just be forgetting something!
Rkive
Post Mon Nov 05, 2007 3:29 pm
I can see 3 bolt heads, but am having trouble removing them, do they just screw off?
I have tried with a knife but im afraid I will bugger the groove as they are pretty tight.
FWD is for Pussy's
Ziggy
Post Mon Nov 05, 2007 3:39 pm
Sounds about right... should be able to get a socket on them easily enough? Not sure what you'd achieve with a knife... :?
