I want to re-do my headlamp rings satin black. The last ones I did the paint came off and someone (not here) said I should have used etch primer.
Etch Primer
StuBeeDoo
gooner1
- Out humping Reindeer
Yes mate Halfords. £9 a can iirc.
OBs
Upol Acid 8 is what you want, I believe Hellfrauds do it?
StuBeeDoo
OBs
Is aerosol in a red tin, grey lid and silver writing!!OBs wrote:Upol Acid 8 is what you want, I believe Hellfrauds do it?
Make sure you 'key' the surface with a bit of 1500 - 2000 wetordry / scotchbrite... Although the etch will eat in to it
OBs
gare30
also could be called washprimers if you cant find etch
