Best location for a front amp?
toby
Post Wed Oct 03, 2007 7:11 pm
I bought this kenwood jobbie and was going to install it in the area under the heater controls unless there's a better place?
Toby
StuBeeDoo
Post Wed Oct 03, 2007 8:05 pm
Seen it done, and was going to do it with mine.....
Top of transmission tunnel, forward of ashtray, beneath dash, hidden by centre console.
That what
toby wrote:under the heater controls
you're getting at???
d6dph
Post Wed Oct 03, 2007 8:08 pm
Quite a warm area to put an amp in imo, Not a lot of cool air passing over the amp.
mattG
Post Wed Oct 03, 2007 8:11 pm
In my mk2 & 3 escort days under the front seats was the way,
BTW Toby did you get the megasquirt?
(\__/)
(='.'=)Simon13 wrote:
323's were dangerous this will un drivable in the wet!
MattG - hedgefinding specialist
E21 turbo
Can be your new sig matt!
StuBeeDoo
Post Wed Oct 03, 2007 8:14 pm
d6dph wrote:Quite a warm area to put an amp in imo, Not a lot of cool air passing over the amp.
That was why I didn't do it that way.
Toby, if you're interested, I can post pics of my Touring amp install solution.
toby
Post Wed Oct 03, 2007 8:22 pm
StuBeeDoo cheers, it would be good to see pics of another option.
It's the heat that concerns me. Have fitted an Alpine amp in a previous E30 in this location with no probs but it looked to have better cooling ducts than this new one.
mattG, MS is on my xmas list, but I don't think I've been good enough and Santa knows.
StuBeeDoo
Post Wed Oct 03, 2007 8:43 pm
OK, here's what i did with the amp. I designed the box from scratch and built it with 9mm ply (same as Touring boot floor).
The sides are left open to allow a bit cooling. I don't have it above half-volume at all, but on a 4 hour drive I had it on constantly with no problem - overheat or otherwise.
I cut the front section off the boot floor. The floor comes out to allow access to the spare wheel without having to move the amp box.
The box is slightly under 3in deep. I use the boot for loads quite a bit and have yet to find load carrying a problem. The lid does lift with the box in situ for access to the amp.
Hope this is some help to you Toby.
mattG
Post Wed Oct 03, 2007 9:18 pm
Nice work stu, what size are the rear speakers on the sides?
(\__/)
E21 turbo
StuBeeDoo
Post Thu Oct 04, 2007 2:14 am
mattG wrote:Nice work stu,
Thanks Matt. :thumb:
mattG wrote:what size are the rear speakers on the sides?
They're 13cm Infinity's
With the benefit of hindsight, I should have gone for 6x4's - they would have fitted better. Not sure if anyone does that size component speakers though.
miniblob
Post Thu Oct 04, 2007 9:54 am
Stu - thats a nice tidy install mate!!!
That's one place i hadn't thought of putting an amp and it's given me an interesting idea - although my amps are a bit bigger than yours!!!!
Someone else had a thread on here fairly recently about putting an amp under the heater controls - not sure if they did or not though!!
Would think it will depend on the use etc really, and i think i suggested it could be vented - you could fit a small pair of fans, pulling air from one side of the console and sucking it out of the other.
Personally, i think it's a nice idea, but it'd get way too hot under my kind of abuse!!!!!!!!
327 Touring with bass!!!
1an
Post Thu Oct 04, 2007 10:09 am
miniblob wrote:Stu - thats a nice tidy install mate!!!
also another problem would be with coming up to winter, you would be using the heater more so therefore heating it up more,
best thing i can think of would be to mount it in the boot, i know you would have to run longer cables but it wont make that much difference.
SHAKEELE30
Boost Junkie
Post Thu Oct 04, 2007 11:57 am
Ive put mine under the passenger seat! Easy to access, pretty well ventilated there to...
StuBeeDoo
Post Thu Oct 04, 2007 12:47 pm
SHAKEELE30 wrote:Ive put mine under the passenger seat! Easy to access, pretty well ventilated there to...
That was one of my first "preferred sites" as mine is a Touring. I decided against it as Wor Lass is somewhat large and has to have the seat adjusted right down and back. Wouldn't have left enough clearance.
toby
Post Thu Oct 04, 2007 5:19 pm
I'm going to mount the amp up front though as my 'boot' is full already with stuff. As I say, I've fitted an amp under the heater controls before without problems so I may risk it with this amp in my current car too. What's the worst that can happen? I'm not worried.
What a cool thread - StuBeeDoo that's a great install! :thumb:
StuBeeDoo
Post Thu Oct 04, 2007 6:34 pm
Thanks for the comments lads. :thumb:
If a job's worth doing, it's worth taking time over and doing properly. :D
toby
Post Thu Oct 04, 2007 6:45 pm
Not great for front speakers though - too much cable farting about :cry:
StuBeeDoo
Post Thu Oct 04, 2007 7:37 pm
toby wrote:Not great for front speakers though - too much cable farting about :cry:
Ain't that the truth!
I've only got the rear's connected to my amp.
touringandy
Post Thu Oct 04, 2007 11:18 pm
true wouldnt sudjest putting it there that area bakes were the fans are
you wish
toby
Post Fri Oct 05, 2007 8:31 am
This amp is to drive my front component set up. (Why didn't I say that at the beginning?!)
StuBeeDoo
Post Fri Oct 05, 2007 9:03 am
toby wrote: Why didn't I say that at the beginning?!
D'OH! :lol::lol:
BadDave
Post Fri Oct 05, 2007 10:08 pm
This is what i did with mine
The amps for front and sub are hidden behind the rear seats and the amp for the rears/crossovers are hidden under a false floor
toby
Post Tue Oct 16, 2007 2:39 pm
Ok I've had a rethink and am going to put the amp in the boot area somewhere.
I'm hoping there's enough space behind the side panel for a concealed install.
Thanks for all the pics and inspiration zoners.
BristolBulldog
Post Wed Oct 17, 2007 10:59 am
might be a little extreme, but what about a fake floor in the front passenger well, or behind the drivers seat maybe? and then jsut use one or two pc fans linked to ignition t keep it nice and cool?
toby
Post Wed Oct 17, 2007 6:28 pm
I think behind the trim panel in the boot is favorite, for me anyway. I'm after a stealth install.
toby
Post Mon Oct 22, 2007 10:06 am
It went in there quite nicely in the end, with no interior space lost at all.
Not quite the standard of some other installs on here and I'm grateful for your pics.
Toby
StuBeeDoo
Post Mon Oct 22, 2007 10:18 am
Nice one Toby. :thumb:
