hi all,
just been to look at a 318i tourer as 325s are few and far between,
1991
139k fhs
17" alloys, not to my likings but brand new,
£900 ono asking price
only thing is its been lowered excesively on the rear,
what stresses does this cause on what parts, what will i need to replace, its only been like this for around 3 months?
id like to raise it a little so what price will i be looking at for rear struts/springs -40?
quick replies if pos, im going back tomorrow in the dry to take a better look!!
cheers
lowering advise
toby
If it's too low at the back it may have been lowered with saloon springs (sounds likely in your case) - which aren't so sturdy on the rear - or the rear subframe bushes may have collapsed.
New spring kits (lowered 35/40mm) can be bought from GSF or Eurocarparts for around £80 and rear shocks about £60 for both.
My touring is lowered 35mm and I have few problems.
sp82
it was like riding on a trampoline, i banged my head twice while taking a ride in it, it was that stiff, so would i be looking for bushes?
what price would i be looking at for a full poly bush kit?
toby
Forget poly bushes unless you won't less grip and noise vibrating into the cabin.
Rear subframe bushes are a £250 garage job. Use genuine BMW bushes.
From what you say it's hard to tell what the problem is with the car. On the one hand you say it's like a trampoline, which would suggest it's soft but you say it's hard on the other hand. Maybe it's been lowered too much and you'll have to change springs and dampers.
sp82
sorry mate, its stiff as fook, every little pebble on the road makes the car jump.
it that low you cant see the top 1 1/2" of the alloy, its up inside the arch.
toby
It will be new springs and possibly shocks then.
snoops
- Major Helmet
check the tire pressures, mine was like this when I picked it up then when I checked the tire pressures which where 50psi!!? I lowered the psi and it was better even though mines lowered around 80+mm
sp82
also, where do i get some factory looking side skirts?
new boot carpet?
cheers
new boot carpet?
cheers
