AMP HELP!
snoops
Major Helmet
Post Tue Jul 24, 2007 6:31 pm
ive got an amp Predator 600W and a wiring kit, where do I connect the \Earth Cable? theres only 2 places on the amp 'RMT' or 'GMD'?
I connected the power cable to the 12V+ on the amp? is this right?
stitch-626
Post Tue Jul 24, 2007 6:53 pm
i'm pretty sure its gmd, rmt will be a thinner wire that you connect to your head unit as a remote switch to stop it killing your battery.
hope this helps bub
ian
wanted passenger side rear door for touring.pref dark blue
wanted, toy Bmw's any series, not for me for my 3year old daughter.
I have a rondevous with death, i drive an E30 in scotland
eko
Old timer
Post Tue Jul 24, 2007 6:54 pm
12 volt to battery
Remote to back of stereo(usually Blue)
Ground is to car body(Earth)
munky30
100% Pure Council
Post Tue Jul 24, 2007 6:59 pm
Make sure you get a good earth point. A bolt that goes into the body work, then sand the paint down around it to get a good contact.
stitch-626
Post Tue Jul 24, 2007 7:01 pm
boot lock is a good point if you ave enough wire.
tomtomiS
Post Tue Jul 24, 2007 7:14 pm
stitch-626 wrote:boot lock is a good point if you ave enough wire.
or drill a hole ( obviously not drilling through anything important such as fuel tank etc) and bolt it from both sides so its secure, thats the best way to earth ur amps
snoops
Major Helmet
Post Wed Jul 25, 2007 12:48 am
thanks for the info:thumb: will try tomorrow
