16's or 17's???
Straightsix83
Post Sat Jul 21, 2007 3:23 pm
Good Afternoon All, just had a bit of a dilemma with regards to which size alloys will work best. I have heard that with 17's you can compromise handling to some extent and the arches may rub. Has anyone experienced this. Other than 17's i was thinking maybe wider 16's would work better but the same probs may occur. Any light anyone could shed would be great as im a month into E30 ownership and need to absorb as much as possible. :D
iDreamBeemer
Post Sat Jul 21, 2007 7:52 pm
Alpinas can do a staggard setup with 7" fronts and 8" rears, there are a few others around depending on your budget.
If you want to keep the handling (without some serious modification to allow for bigger wheels) 16" are as big as you want to go.
snoops
Major Helmet
Post Sun Jul 22, 2007 8:59 pm
17" should be fine depending on how low the car is
tailoutcharlie
Post Mon Jul 23, 2007 6:54 pm
personal preference i think matey, try and borror to try each, i live in speedbump central and changing to 16s from 17s was a hell of a lot better, also have vastly imroved handling on b-roads which is a nice fringe benefit winkeye
Chris
FormerMember
Post Wed Jul 25, 2007 12:01 pm
You can really slam the car with 16" (or even 15") which you can't do with 17" rims. Anyways, it's all up to your personal preferences.
Good tires make up the handling more than rim-size (if the width is 6-8").
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
Ajay325
Post Wed Jul 25, 2007 12:04 pm
16"s all the way... I have 17"s but handling is more desirable...
siddiqi1
BFG Zone Contributor
Post Thu Jul 26, 2007 11:22 pm
I have 18" Kahns........dropped 40mm at the back anmd no rubbing anywhere even when fully laden with people
However as you can imagine, i can iften feel the bumps very well through the car, handling is exceptional, though i do feel that it acclerates slower but once it gets in its stride its off
Personally i think you're best with 16"s with a nice tyre with some absorption.
Saboor
whipsey
Post Thu Jul 26, 2007 11:52 pm
i'd probably go for 16's and a nice drop :P
