Would a Interior from a 4 door E30 fit in 2 door?
Privateye
Just wondering if a 4 door interior will fit in a 2 door E30. I know that the door cards will not and they will not have the seat leavers for passengers to get in to the back. I have a mate who can fix this. I just need to know if the front and back seats will fit. The seats are taken fron a G reg 4 door E30 and i wish to fit them in a E reg 2 Door E30.
jordano
my interior was buggerede in mine so i got a full interior out of a 4 door and just put all off the mecanisms into them from my 2door seats and they worked fine, so yes they will fit
Privateye
How hard is it to put in the lever mechanisms?
beemerboy3
not that hard jst play about wit it
dazleeds
- old skool raver
take a bit longer but if you take the cloth from the four door seat back and put it onto the 2door frame then swap the frames over whaalla you have a new two door interior plus while your at it you can pack in some more padding from the scrapper seats and get em more comfy swapped mine over to leathe r but didnt do the padding so prob redoo em at the weekend only takes an hour or so to do properly Daz
www.oldskoolfantasy.co.uk
Simon
Only difference in the rear seats is the base of the 4 door seats have a small cutout in the corners.
Fitting the tilt levers and the wires is all that's required to enable the front seats to tilt, the mechanism is already there.
