Cab rear speaker depth?
funkdocta
Post Sat Jun 30, 2007 12:43 am
Hi does anyone know how much room there is in the rear speaker holes in a cabriolet?
Just bought some speakers, they're about 60mm deep, just not sure if they're gonna fit!
I've done a search and the closest I found to my answer was "about 2inches" but I'm after the exact depth if anyone knows?
B51ngh
Post Wed Jul 11, 2007 4:04 pm
Not sure about exact depth, but if you pop the cover off and unscrew the stock speakers you can just place the speaker there to see if it fits. Trouble I had with that is some of the old speakers I had were either too big to fit there or the ones that where the right size depth wise did not span across the space making it impossible to screw into the side and also stuck out so when replacing the panel it did not fit again! Crazy.
