tech1 ice install mmmmmmm
dazleeds
old skool raver
old skool raver
Post Wed May 16, 2007 2:35 pm
i think maybe i have gone a bit ott with this but you tell me :cool:
2 x MTX Thunder 4320 Amplifiers -
1 x Phoenix Gold Line Driver PLD1 -
1 x Phoenix Gold EQ215ix Graphic Equaliser
four 5 1/4â€a 2 way speakers manufactured by Mac Audio
2x7"midbass woofers cambridge soundworks
kenwood psw9524 mp3/cd head unit + remote
ALPINE V-POWER MRP-T130 amp
jbl gt3-15 sub or 2x12" subs not decided yet winkeye
just wish i knew where to start with all this :mad:
www.oldskoolfantasy.co.uk
dazleeds
old skool raver
old skool raver
Post Wed May 16, 2007 2:44 pm
ps anyone got any tips on split charge systems as im pretty sure im gonna need a second battery :mad:
maxfield
Post Wed May 16, 2007 2:46 pm
Not OTT but :cool: :cool:
DrBen
Post Wed May 16, 2007 2:49 pm
looks promising man! I'd go the 15" sub! winkeye
aceraf
Post Wed May 16, 2007 5:27 pm
Nice bit of kit....
where do you plan on mounting the speakers...are the 7's going on the rear shelf or door cards?
Breaking 325i Touring
kingcruizer
Post Wed May 16, 2007 6:42 pm
no need for a second battery, just get your self a 1.5 farad capacitor, that'll keep the juice flowing.
p.s if you dont use that equaliser i'll buy it off you winkeye winkeye
"BEFORE I DIE, I WANT TO OWN A CAR WITH AN ENGINE THAT STICKS OUT OF THE BONNET"
zaust
Zone day release
Post Wed May 16, 2007 7:04 pm
kingcruizer wrote:no need for a second battery, just get your self a 1.5 farad capacitor, that'll keep the juice flowing.
Spot on..
M30 Tech 1 Touring on gas.
chu346
Post Wed May 16, 2007 7:09 pm
kingcruizer wrote:just get your self a 1.5 farad capacitor
that's debatable, second battery is better.
kingcruizer
Post Wed May 16, 2007 7:13 pm
far easier to install though and does the job a treat
320Touring
Post Wed May 16, 2007 7:18 pm
is it just me or does your boot look big daz????
looks like some bangin oldskool choons soon to be heard up here-whilst you're in Leeds... :cool:
chu346
Post Wed May 16, 2007 7:20 pm
kingcruizer wrote:far easier to install though and does the job a treat
have a look on talkaudio.co.uk and see what they say about them. If you need one you would be better off with a second battery.
kingcruizer
Post Wed May 16, 2007 7:31 pm
im not disagreing with you on that but for what hes installing it would be fine.
ive got two yellow top batterys and three 2 farad capacitors to run my install. ive done many installs and have always used them. i love my i,c,e comps. even better when i win.
choppa7
Post Wed May 16, 2007 8:49 pm
I dont think I've sen an equaliser like that in a car before :?
Starting point, new battery, then 2nd battery, make sure youre using decent cable too otherwise you might as well have thrown the dollars out the window :wink:
1990 318i Lux
BadDave
Post Mon May 28, 2007 1:26 pm
dazleeds wrote:ps anyone got any tips on split charge systems as im pretty sure im gonna need a second battery :mad:
1st mount the aux battery securely in place
Mount the split charge relay
You'll need 2 inline fuses or circuit breakers.(1 near the relay and one near the 2nd battery)connect the main battery to the relay with a short length of (minimum 4 guage/pref 0 or 2 guage)cable.run a short length on (same guage)cable t the front fuse/circuit breaker.Same for the rear fuse /breaker.Then join up the 2 fuses/breakers with same guage power cable.
For the wiring to "switch over" the relay.1 goes to earth and the live feed is best to come from the alternater.Take it from the terminal/wire that feeds the charging light for the intrument cluster(at the alternater end tho)
That way,the 2 batteries are only physically connected when the engine is running and you won't discharge both batteries when your parked up and using your sound system.
The 2 fuses/breakers are to prevent electrial shorts if tthe charging cable for the 2nd battery ever touches any of the metalwork due to poor placement/routing through the car from front to rear.
HTH
