I need to swap the front speakers in my touring.
Can anyone recommend any coax speakers that will fit in the front? I don't want to spend a fortune and can't be bothered with components and tweeters etc, so i'm after just a straight swap into the original fittments.
I did try a pair of Kenwood Dual Mag's i've got, but they were too deep.
Someone recommended these to me, but i'm not sure?
http://caraudiosecurity.com/shop/produc ... /2851.html
Front Speaker Advice
andye30nut
- E30Zone Contributor
infinity kappa 13cm speakers staright in no hassel great sound thts what ive got in mine mate
iDreamBeemer
I plan to fit mine tomorrow but for exactly the same reason...easy to fit and good quality.infinity kappa 13cm speakers staright in no hassel great sound thts what ive got in mine mate
Once the full install is complete I am going to do a little write up from my experience, I hope it will be of use to people. I did some searching and I found the kapp for £59.99 + postage but the link is at home (and I am at work...)
Morat
Is the original wiring up to it or did you replace it?
iDreamBeemer
Is that to me or Renton? I (will) have 2 amps, 1 for sub and 1 for the other speakers.....Is the original wiring up to it or did you replace it?
andye30nut
BASSJUNKIES.COM BEST PLACE TO GET THEM.
I POST PICS OF THE INSTALL THAT I STARTED IN THE 320I THEN RIPPED OUT
munky30
- 100% Pure Council
no point doing that unless you uprate the speaker wires.iDreamBeemer wrote:Is that to me or Renton? I (will) have 2 amps, 1 for sub and 1 for the other speakers.....Is the original wiring up to it or did you replace it?
shouldnt this be in the ice section?
ian332isport
Indeed it shouldmunky30 wrote:shouldnt this be in the ice section?
chinchilla
Is it easy to do replacing speakers? i would like to do the same and dont want to get ripped off by ICE installers and there 'labour costs', i would like to replace the wiring as well with some chunky oxygen free wires.. and how do i get wiring to the rear panels in my cab? there is no speakers or wires!!
connorb16
Just put infinitys in my fronts with new cable, sounds great and easy to fit.
aceraf
NEVER GO THERE!!!BASSJUNKIES.COM BEST PLACE TO GET THEM.
they're a bunch of jokers.....i went there for a alternator swith charge relay, and the fools tried selling me a 0.5 farad power cap!!!
They also thought they could get 4 audiobahn subs (which need 3.5cuft each) into the boot of a nissan sunny,....when i had my back seats out to fit 4 15's that were in 1.9cuft boxes!!!
Biggest bunch of jokers i've seen!!! Even worse than MotorMax....
Mind you, not sure if it's the same people in other sites....the one i went to was in Derby, and i know they have other sites, but not sure if it's a franchise or the same people..!
Breaking 325i Touring
