Few questions for the Ice orientated out there.
Right i went into Dynamic Sounds on Walworth rd on the weekend with the intent of getting some kind of idea of a way to wire up two amps without having to buy two amp wiring kits (wish i did'nt know but hey )
and the geeza in the shop told me to buy this wiring kit that allows you to use two amps....So i did........Now i've got the kit in my room and i'm starting too wonder....Is this all neccessary.....The fused power distribution block that comes with it uses 4awg cable from the battery an splits it into two 4awg cables....which are fused with ANL fuses with 150amp ratings.....Now i've just got a sony Xplod 2/1 4 ohm (W) 2 x 55W rms (for my front speakers and a Crunch Blackmaxx MXB2250 2 Channel Amplifier rated at 2 x 250 Watts @ 4 Ohms 2 x 500W @ 2 Ohms
1 x 1000W @ 4 Ohms not Rms figures....Cant find them only one i can remember for sures is 1x 750w rms @4 ohms (For my sub/subs).Can i run both the amps from one of the 4awg wires of the fused distribution box by putting a 1 into 2 power distribution box at the end of da 4awg wire.....???? Sorry if this is confusing
Thanks for the help in advance
Rnl84
