I got allthe bits but was working out the connections for the 2 speed fan-where is the temp sensor for the relays supposed to be?
e30 air con
patch
Hi everybody Have any of you added air con to your e30?
ian332isport
The temp switch normally fits in the drivers side of the radiator. Unfortunatly, unless you have the aircon radiator, or an aftermarket one (they usually have a blanking plug in the side), you won't have the required hole.patch wrote:Hi everybody Have any of you added air con to your e30?
Ian.
