5.25 mids and tweeters, with sound deadening behind speaker and crossover hidden behind the glovebox housing.
No rear speakers
2 subs in the boot. I am going to try the 2 focal 5WS that i have. They only require 5ltr size enclosures without porting.
Pioneer head unit and rockford fosgate power 1000 amp. I was going to use a PG M44 old skool amp, but decided on RF. The M44 is also for sale.
I built one sub box to fit underneath the roof storage compartment. I have angled the speaker mounted face.
I was going to put a box on the opposite side of the boot, but the RF amp i'm getting is 23" long, so another location was required.
I noticed water had seaped in from the lights as the foam is old, so i pulled the carpet and noticed that water had gone down the recess on the petrol flap side. I removed the panel and then removed the huge weight that was in there as well. Dried the area up and decided to use this to put the second sub box in. I also needed to remove the boot ledge trim to enable the box to fit.
I have angled the direction of the speaker towards the back of the car and also to angle the speaker in the box.
The back of the box sits on the floor pan and the front will be fixed to the raised lip by 3 screws. It sits in the space very tight as well.
