Project council! 'I' lip on tech 2 bumper
d6dph
Post Mon Feb 19, 2007 3:36 pm
After seeing the pics of Simon13 & Demlot's recent additions to their front bumpers, I decided I would try something I have been thinking of for quite a while.
I am using a standard 'I' lip mounted below my tech2 front bumper. this will probably look crap and cause me untold amounts of problems but I'm up for a giggle so here we go!
I started off by using blocks of wood to sit the lip below the bumper to get an idea of the work needed.
Obviously the general shape is good (it is off of an E30 after all!) but there are areas that need modifying to fit the bumper correctly.
1. Centre of bumper is a more pronounced curve than the I lip. I am planning to cut small triangular sections out across the top to allow it to curve, then fibreglass and epoxy resin back together to keep the strength.
2. Corners of the tech2 bumper are a softer radius than the I lip, not 100% sure how to get round this yet. Any idea's are welcome.
3. The return to the wheel arch is too short, luckily I had already been advised by Ant of this, so I have an extra lip that I will cut and join to extend this section.
It's certainly going to be low enough, Hence I have named this job "project council" :lol:
To get a good idea of the curve I need to work to for the centre, I placed a plank of wood under the bumper and traced the shape.
Then drilled holes in the wood and bolted the lip to it, forcing it to take to the extra curve.
I am planning on cutting the lip with a dremel whilst it is still attached to the wood, then doing the fibreglassing to form the shape. The theory is that when I unbolt it from the wood, it should be the right shape for the bumper?
Now this could end in tears and not work at all, But at least I tried :lol:
maxfield
Post Mon Feb 19, 2007 3:38 pm
Looks good could see this being quite nice!
Been wondering day what project council was :D
Post Mon Feb 19, 2007 3:43 pm
deviant :D
should go with the mandatory Laguna front splitter for proper council respect dave, making sure of course that the Mtec goodness gets ripped off at the first sight of a speed bump :mad:
d6dph
Post Mon Feb 19, 2007 4:15 pm
I hope it will look good Max, Not really cost a lot if it doesn't.
Lee, Unfortunately my car doesn't have the power to back up a laguna splitter, You need at least 80hp at the front wheels don't you know :twisted:
cliffybabe
Powered by Nelly
Powered by Nelly
Post Mon Feb 19, 2007 8:22 pm
Dave looking good mate, love the little blocks of wood :lol:
shazE30
Post Mon Feb 19, 2007 8:29 pm
Was gonna do somthing similar but then imagine your front valance getting ripped off on a speedbump
It will definatly have cost alot then! Will look good but only for the brave Good luck tho :D
Cotty
Hartge Crew
Post Mon Feb 19, 2007 9:26 pm
d6dph wrote: I am using a standard 'I' lip
I take it thats different to an 'IS' lip as mine looks a lot deeper than the one I saw at Lakeside
essexboy
Post Mon Feb 19, 2007 9:37 pm
If he had the s aswell it would have turned into an expensive experiment, mayb that will come next if this goes to plan winkeye
d6dph
Post Mon Feb 19, 2007 9:49 pm
Yup its the std I lip Paul, Approx 30mm deep.
And thanks to whoever made me a council deviant :lol:
cliffybabe
Powered by Nelly
Powered by Nelly
Post Mon Feb 19, 2007 11:27 pm
d6dph wrote:council deviant
Wicked another Deviant :twisted:
tylerma
Post Mon Feb 19, 2007 11:30 pm
d6dph wrote:Yup its the std I lip Paul, Approx 30mm deep.
winkeye :wink:
stuartgallafant
Post Tue Feb 20, 2007 10:41 am
looking good mr dave!! you dirty council fool!!
d6dph
Post Tue Feb 20, 2007 10:45 am
Yeah, We may have a slight problem :lol:
I have been doing all the test fitting in my garage, which is up a slope. Normally when I drive the car out I have about an inch of clearance between the bumper and the floor at the bottom of the slope. The lip is about 30mm.......
Can anyone else see what I am getting at :roll:
stuartgallafant
Post Tue Feb 20, 2007 10:46 am
d6dph wrote:Yeah, We may have a slight problem :lol:
:teehee:
tylerma
Post Tue Feb 20, 2007 10:52 am
danger danger will robinson the lips about to get crushed
ha ha ha
sorry having a mental episode
d6dph
Post Tue Feb 20, 2007 10:55 am
Malc, Put down the crackpipe and go see the doctor! :mad:
dazleeds
old skool raver
old skool raver
Post Tue Feb 20, 2007 11:07 am
what ya want is some pimp my ride actuators winkeye
1 flick of the switch and ur extension will pop up into the front mtec
then aanother flick when ur out on the flat will drop down ur badboy council lip for full effect :flipbird:
www.oldskoolfantasy.co.uk
Cotty
Hartge Crew
Post Tue Feb 20, 2007 1:24 pm
dazleeds wrote: what ya want is some pimp my ride actuators winkeye
Oh suits you sir :giggle:
d6dph
Post Tue Feb 20, 2007 2:26 pm
Yup, It's abandoned!
I had f-all clearance to get off of my drive, and it's not that steep! speedbumps and carparks would have been painfull.
Ah well, I tried :cry:
stuartgallafant
Post Tue Feb 20, 2007 4:04 pm
:lol:
well at least you tried big dave!!!
cliffybabe
Powered by Nelly
Powered by Nelly
Post Thu Feb 22, 2007 4:44 pm
d6dph wrote:Yup, It's abandoned!
:lol: u tried dude that all that matters :(
TW166Y
Post Thu Feb 22, 2007 5:16 pm
dave stop ...............
keep this very thought matey! Get yourself down the scrappy and hunt for a luguna!
When you find one in the yard take a look at the front bumper, also pay particular attention to the lower section. You will understand what i mean when you see it!!
Project ruuude bwoy, starts all over again! :cool:
Saying goodbye to 4-pot wrongness
baxter
Post Thu Feb 22, 2007 5:23 pm
you could use a rs2000 splitter, there rubber and flex :?
Post Fri Feb 23, 2007 11:47 am
oh Dave, if your gonna come out of the closet as a council deviant, you really should finish what you start..
TW166Y
Post Sat Feb 24, 2007 1:30 pm
baxter wrote:you could use a rs2000 splitter, there rubber and flex :?
bingo dude! same as the laguna one! :D
d6dph
Post Sat Feb 24, 2007 1:34 pm
But that and the laguna splitter will look like a stuck on bit of plastic.
I was aiming for an OE look, I may still try this, but i need to make mounts that will either break away or unclip if an impact takes place.
Think of this as on hold rather than cancelled! :twisted:
fuzzy
He who sleeps with "Gingers"
Post Sat Feb 24, 2007 1:36 pm
are you going to colour code the little blocks of wood and wont the little blocks of wood get broken off when you go over a speedbump?
TW166Y
Post Sat Feb 24, 2007 6:58 pm
dave trust me mate it doesnt look like a stuck on bit of plastic, its rubber for a start :mad: :P
My mates just done his and believe me mate it looks great :cool:
