m3 fibre glass kit
mnmbm325
Post Thu Feb 15, 2007 3:12 pm
after searching all over i've found an m3 kit :) but its in fibre glass :? , just wondered if anyones fitted an m3 kit? i'm trying to find out how much the metal rear arches are?
are the kits hard to fit? do they need allot of work on the inner arches and in and around the fuel cap?
does anybody have any pics of step by step fitting the kit
cheers
tobias
Post Thu Feb 15, 2007 5:06 pm
i do believe c3bmw sell original rear arches for about 360 each side plus vat
BristolBulldog
Post Wed Feb 21, 2007 10:23 am
Ahhh, finally! (sorry for the delay mnmbm325). i'll wack a few photo's up here, and ask away. I've put the full metal kit on with no previous experience, so can give you a first hand account if you need it.
here's a few picks to get you started.
Before i started
arches brought back from london
arch getting ready to rough trim it
trimmings from arch
one arch trimmed back
one arch dry fitted
cut back original arch
weld up original arch, and take back where it will be welded on
tack on with gas mig, 0.8mm wire, over flow on gas, and lowest amper you can get a bead at (this all help to prevent panel distortion).
loads and loads of this
and this
ends up like this
and this (for rough)
let me know if there's anyting else you need to see/ know, and sorry for how long it took to reply![/img]
mnmbm325
Post Wed Feb 21, 2007 7:07 pm
cool that helps allot, how did you sort out around the fuel cap? is there any welding to be done there? also inner arches, can you buy them or are they part of the arch.
this is a great help. have you got a pic of the final projest?
cheers,
martin
MAJ-POWER
Post Sat Aug 16, 2008 5:58 pm
exactly what i'm doing. any more pics of how you went around the rear lights?
MAJ-POWER
Post Sat Aug 16, 2008 6:22 pm
http://i116.photobucket.com/albums/o6/B ... ort918.jpg
How did you manage to get the panels flush, without a hump, if ou jus welded on without cutting off the original quarter panel
BristolBulldog
Post Sun Aug 17, 2008 12:09 pm
Hey guys. sorry i've been away.
I have two othe threads, but they are on the bimmerforum. Not sure if i'm allowed to post a link?
To get the wing flush, i did the stitch weldin with a really low amperage welder, thinnest wire (0.8 mm i think?), and about twice as much gas on the mig as you would usually have.
THis was because i was warned by multiple people who said icouldnt do it, that even if i could i would deform the panels from the heat.
So i stitch welded it as you can see here.
To get the wing flush presented its own problems.
I pepped the inner wing like this?: -
By running angle grinde with a big stainless steel wire brush on it, to get a clean 1+ inch clean bit of metal.
I kept trimming the wing up with 1mm cutting discs off ebay (be aware these will spit and embed grit in your forehead!!!!!)
and once i had a good dry fit
i then had to knife edge most of the edges. THis was the difficult part. As i sharpened each edge to make it blend to the wing (basically i ground the back edge from each joining face on the m3 wing),
i made the metal thinner, which naturaly made it even harder to weld.
oh, i forgot. cut the original wing high, and weld the skins back together. Have a friend in the boot ready to blow out the insulatin that keeps catchign fire (its not serious).
When you cut the outer arch do not do it exactly as i did it above. I should have cut just the outer face, and left it almsot like this: -
because i could have then welded the existing inner arch to the innder of the new m3 arch. As it is now, i ended up putting cuts into my welded inner arch, and be nding the tabs out to fit my m3 inner, but i will have to add additional metal in now.
The m3 front arch is rather simple.
I fitted the saloon arch to the m3. Its the same except for the bottom.
clean the original arch up.
dry fit the m3 arch
it will fot something like this.
cut the bottom off of both arches, and tac the normal bottom of the wing ontothe m3 wing whilst on the car like this.
then take it off, and weld together like this.
and then
done! Hopefully your welding is better than mine!!!
Fuel flap i have no pics of uploaded at the mo.
But what i will be doing is buying the m3 filler neck, so it fits to the original wing. The only thing you have to do is cut a nice hole in your original wing so that you can re-locate the central locking solenoid for the filler.
I intend to make up my inner arches below, and then bond a section on around the inner fuel flap (on the original wing). after that i will pump in expanding foam to help stop any vibration, and minor dents, it will also make the whole rear end better possibly, and not weigh anythign compared to the extra wings.!? besides its cheap stuff!
I'm actually glad i did it this way, as the e30 doesnt have enough weight at the rear, considerign the weight of the m30 up front!
hope this helps you guys.
Here's a few recent pics to show i am still doing it!!!
and im still looking for a front m3 bumper re-enforcer/ support if anyone has one!!!!!??????
MAJ-POWER
Post Sun Aug 17, 2008 12:51 pm
thanks for that, it was great help. cheers :cool:
MAJ-POWER
Post Sun Aug 17, 2008 3:52 pm
cant the e36 m3 bumper re-enforcer be modified to fit the m3 bumper?
BristolBulldog
Post Sun Aug 17, 2008 8:41 pm
Lol.
Thats exactly what i'm looking at. The standard e36 front bumper carrier on my other halfs, looks like a strong plastic, perfect for fitting it etc. So i jsut needto source one.
i might just get her he m3 front bumper then pinch hers!
Did loads of cleanup today, fitting seals, door trims, rear lights etc, jsut toclear some space. Found all the front grills etc lol!
MAJ-POWER
Post Sun Aug 17, 2008 10:34 pm
the re-enforce for standard e36 bumpers can be grabbed for around £20 on ebay. loads of breakers on there as well.
what mig welder did you use? is it that little blue one?
BristolBulldog
Post Mon Aug 18, 2008 8:11 am
Yep, i'll probably see what i can find on there this evening.
Yep, i used the b lue one, el-cheapo from machine mart. The only real thing i wanted was a low amperage mode. I can't remember it all now, as that part of the project was 2+ years ago, but it had to be a gas mig, low amperage.
I forgot to mention. Once i had stitched the wing with weld, i then filled in the gaps, so it is fully seam welded. Took a reasonable amount of grinding and re-welding to get it right, but its almost perfect now.
MAJ-POWER
Post Mon Aug 18, 2008 1:57 pm
a bodyworker i know, claimed that these little mig welders are useless. i think you can get one of these for around £100-£150. which i was looking to do until he had put me off.
so now that i see you done your with that, i think, i'l go and grab one this weekend. but i'm actually thinking of cutting the existing quarter panels off, and joint welding. cos i dont want a bump, by stitch welding. i'm jus surprised how you managed to avoid that
BristolBulldog
Post Mon Aug 18, 2008 6:52 pm
you don't get a bump if you blend the wing properly and grind back. Even around the rear light its not too difficult.
I've had people ever since the start of the rpoject, and even now tell me how it can't be done, or how i can't do it. I listen to them always, and only once or twice throughout the whole project have they ever been right.
If yur not a great welder like me i would recommend a few good stainless steel wire brushes, and some extra angle grinder discs.
That way, you can put stitch on, wire brush it back clean for the next weld, and build up if need be. I did all the welding on the wire reel it had with it!
I rarely got it to weld on minimum amperage with no spitting at all, but on very clean parts, where the existing wing, and the new were held together well it went perfectly pushing into the existing metal nicely.
I was going to cut off the original panels, but thats structural, and your really getting into stuff that i had no understanding of. This way, i can only strengthn the car in the event of an accident etc, and was also concerned as these wings are spot welded and braised in parts.
MAJ-POWER
Post Mon Aug 18, 2008 8:01 pm
but isnt there more chances of the filler cracking on stitch welding, due to the vibration between the panels, as they're on top of each other.
fuzzy
He who sleeps with "Gingers"
Post Mon Aug 18, 2008 8:09 pm
he welded in the gaps between the stitches.
MAJ-POWER
Post Mon Aug 18, 2008 8:56 pm
i was goin to pay £300 to get my old ones cut off and the m3 ones welded. but now, i'v picked up a 25-130 variable amp mig/gas welder for £40. lol.. so just going to weld the skins.
however, BristolBulldog, are the rear bumper mounts the same. or will they need to be modified. i mean, as the arches are wider, the bumper is obviously a slightly wider. but is the considered in the mountings, or will there be need for modifications?
thanks
Ollie_bwoii
Post Mon Aug 18, 2008 9:54 pm
Maj-power any update with your M3 cab rep????
MAJ-POWER
Post Mon Aug 18, 2008 9:59 pm
i left it to the side, was busy with my both my e36's. work on the e30 will start anytime soon. will post a new thread as soon as i touch it
BristolBulldog
Post Mon Aug 18, 2008 11:24 pm
Maj, this is funny. I've been working loads on the missus's e36 as well! 8 computer faults alone lol.
The rear bumper i'm unsure of. I know it kinda fits with masking tape, and that with welding the wings on the outside, it makes your car about 1.5" wider than a normal m3, and that the flex in the rear bumper works fine with this.
If i remember correctly the pre-facelift rear mounts could be bent. My friend who i have lsot contact with was doing a 4 litre baur m3! and he jsut bought the right parts and they bolted on. Never did manage to get the part number though!
Post Tue Aug 19, 2008 3:51 pm
just needs m3 boot fitting now :wink:
BristolBulldog
Post Tue Aug 19, 2008 3:55 pm
not sure it would look right on a convertible?
Post Tue Aug 19, 2008 3:57 pm
BristolBulldog wrote:not sure it would look right on a convertible?
the genuine m3 cabbys have them dont they
Post Tue Aug 19, 2008 3:58 pm
no they dont :o: :mad:
BristolBulldog
Post Tue Aug 19, 2008 4:57 pm
just plain backs.
i'm keeping the mtec spoiler on the back, for the 3rd brake light, and i'm not amazingly keen on just the plain rear end.
MAJ-POWER
Post Wed Aug 20, 2008 1:47 am
doesnt the bumper look a bit in, in this pic. i think the arches have come slightly far out. or does it fit better when bolted etc.
BristolBulldog
Post Wed Aug 20, 2008 2:00 pm
The bumper in this pic is held there by the concrete blocks, and there are no brackets on the rear side panels yetso thats why it doesn't line up.
Also, the rear arches are a little wider than a standard m3, and there is plently of flex in there to accommodate this.
A4-AHV
Post Wed Aug 27, 2008 9:43 pm
m3 convertibles had m-tech 1 rear spoilers from the factory
BristolBulldog
Post Wed Aug 27, 2008 9:54 pm
harry_p
Post Thu Aug 28, 2008 9:14 pm
A4-AHV wrote:m3 convertibles had m-tech 1 rear spoilers from the factory
no they didnt.
from the factory they all had a bog standard, plain (no spoiler at all) boot.
cheers,
harry
