Mtec 2 kit on a cab
spence_star
Hi guys, are all Mtec 2 kits universal to the model of an E30. Basically someone is selling me a kit of a non cab, and i would just like to know if it will fit straight onto a cab.
cliffybabe
- Powered by Nelly
u will need to slit the side skirt to stretch them over other than that a saloon 2door kit will fit ur cab no probs
E30Mark
Is your cab post - facelift? if not then there is extra work you have to do...
PM for details
PM for details
spence_star
what do you mean slit the side skirts to stretch them over??
Returned after many years out.
cliffybabe
- Powered by Nelly
u have to put slits int he ends of the side skirts to allow them to cover the sills, he is th eman when it comes to this stuff
From memory u have a facelift cab ie Plastic bumpers, bigger rear lights (with round multi plug) as per ur items for slae post and th epics of ur cab u posted recently
spence_star
Its a Facelift
mrLEE30
johnt0709
I am 3/4 way through fitting a tech II kit to a pre facelift car - it has been ok.
For the sills you need to cut about an inch off the edge - you can see the moulded crease, cut down slightly at either side of the part on the sill that attaches to the front wing which will allow it to push tighter. I foound the best way of fitting the brackets was to offer up the sill and mark with a pencil on the car where the brackets should be positioned horizontally and then take your measurement vertically.
An old bracket with the lugs broken off allows you to get the distance between the holes correct to fit the bracket
