Post
Sat Jan 06, 2007 6:43 pm
warm it up with a hairdrier / heatshrink gun if you have one. if that doesn't shift it, they're usually on an adhesive foam pad (to allow it to flex and match the screen) so you can get a scalpel under there. once it's off, a scalpel blade will remove the bulk of the goo and t-cut will finish it off. this is what i've always done and never damaged a screen..... yet....
