ICE wiring
Post Sun Mar 27, 2005 2:16 am
Am thinking about rewiring the ICE on my car as altho they are just standard speakers running off a kenwood headunit i am planning to upgrade them anyways some point soon and also i have to find out why my right rear speaker doesnt work.. im thinking broken wire as it works when you swap them left/right..
Any recommendations as to what sort of wire to use and where from? (nothing too expensive!)
Just thought actually if i rewired it and then fitted an amp i'd have to run all new wiring again wouldnt i? Or could i adapt what would be there?
Dom
Post Sun Mar 27, 2005 5:32 am
if you want speaker wire let me know i'll post you some for a beverage?
If you are going to amp speakers (depending on the power of the amp) it's usually best to replace the wiring with upgraded stuff.
Post Sun Mar 27, 2005 9:02 am
the plan is to amp the speakers in the end yeah.. But im more concerned about the running gear atm.. Plan is to run a 4 channel amp powering the speakers
Was just thinking bout doin it as i got not much to do next week n its just summat to do lol
