M tech 2 side skirt mods for cab
CHRISP
Boost Junkie
Post Sun Oct 29, 2006 6:07 pm
HI e30er Can anybody help me ,Just bought M TECH2 side skirts how do you modified to fit my convertible .
THANK YOU CHRISP
318 turbo cab mint for sale offersImage
Mahmood
Post Tue Oct 31, 2006 1:39 pm
Dude
I have a set of side skirts so do loads of others. Most of us have given up trying to make Tech 1 side skirts fit a cab.
Cliffybabe may be able to assist you as he the only one that I know of who has recently tried to do this.
HTH
robsy
Post Tue Oct 31, 2006 1:50 pm
M tech II sills from a coupe will need cutting at the bottom where it goes under the car - it will then sit flush against the car - as the Cabby ones were deeper to fit along the bottom the coupe ones will not do this - thereofre the nexct best thing is to cut them other wise you will see the bottom of it hangin slightly loose -
My Cabriolet has the saloon ones which have been cut - you cant see it and it looks like factory to all eyes unless you actuially go under neath the car.....
Or you can always go and buy the proper Cabby skirts....but not at that price at the dealers... 8O
E30cabrioman
Post Tue Oct 31, 2006 2:02 pm
same as above ..thats what I did with mine :D and made up a few small brackets to attach to bottom of sills..stretch them to get the look you want winkeye
325i Cab
E39 V8
CHRISP
Boost Junkie
Post Tue Oct 31, 2006 8:19 pm
Thank you all,
I will give it all a try.
JC-bm top bloke also told me there is a fixing part with two holes that attaches to the front wing. When this part pushes against the wing it will try and hold the sill away from the car so cut the two edges of this clip which allows this part of the sill to bend forward, this will make it sit flush and look right.
Any more idears to make it work chaps.
THANKS CHRIS
PS YOUR CARS LOOK GREAT CHAPS
johnt0709
Post Wed Jan 24, 2007 5:58 pm
Hi - how did you get on with your kit - I am in the same boat - just got a tech 2 kit and about to fit to an 89 cab. the pods look ok. I removed the plastic clips that held the old rubbing strip. Most of the holes look in the proper position - I expect this to be a clip on job when I get the plastic plugs for the doors and quarter from the local bm stealer.
I have offered up the skirts and I agree they will need to be cut both underneath and at the front wing. Bit nervy though - once you cut there is no going back - any tips? :eek:
CHRISP
Boost Junkie
Post Wed Jan 24, 2007 9:37 pm
PM sent
cliffybabe
Powered by Nelly
Powered by Nelly
Post Thu Jan 25, 2007 12:02 am
yep the only way to get tec2 skirts on is by slitting them, PM dip346 he will be able to point u in the right direction
