Im thinking of puting a roll cage in my e30 convertable when i do my 335 motor swap because of the added danger lol has any one else done it sure they will have but ive looked for ages and found nothing also dose any one know how little wheels i could fit on my e30(thinking of little deep dish kinda stuff) and what is the pcd and offsets .
Tnx Carl
Cage
placey
carl
cage in a cab? the whole point of the cab was it's level shoulder line. the screen surround is supposed to be strong enough to survive a roll over - wouldn't like to put it to the test though, particularly if there's rust in the scuttle.
14s are the smallest wheels you can run as 13s won't clear the front brake calipers. you could change the brake setup i suppose...
pcd is 4x100. i may be corrected here but i believe the offset varies according to the size of wheel you intemd to run. 16s are good carl - they look right on the e30 and don't spoil the ride. try looking up Borbet type b or konig diva for a couple of dished examples, there's loads more.
paul
paul
i saw a doctor and she gave me some pills....
sunnysr
thx m8 i know i realy like the look of the cab it was the whole reason of buying it but i dnt realy fancy dieing if it all goes wrong so i think i will be geting a cage in if i get the motor swap..either a 335 or american v8(sure the purists would hate that) but i need more power ( i must have the most slugish 325 around its not even close to my e36 325)
thnx for the wheel info i will have a look at them wheels thanks
