This is the adaptor used for the install. Made of mild steel, 140mm OD, countersunk pattern for the 4x100 PCD (to the hub), and 4x114.8 threaded holes (bolting the rims onto the adaptor). Thickness is 22mm. Hub-centering spigot is 57.5mm (to the hub) and 65mm (to the rim mounting face).
This is the head-on view of the adaptor, already bolted onto hub.
Since I did the rear hubs first, make sure handbrake is on, or else it'll be dang hard screwing in the allen-head bolts into the countersunk holes....
Screw in 2 normal rim bolts, put a long bar (handle of the jack) across them and jam the bar into the ground to lock the position. This makes screwing in much much easier...
