Head unit wiring???
Kev_Ush
Post Tue Sep 26, 2006 1:51 pm
I want to fit my alpine head unit but when I took the old tape deck out I noticed someone had butchered the wiring when they put it in :x so now I want to get a proper plug and solder it in, instead of the the twisted wires and sticky tape its got now. Has anyone got a wiring diagram for the cars speakers and power suply? Or at least be able to tell me wire colours and where they go.
dazleeds
old skool raver
old skool raver
Post Tue Sep 26, 2006 1:52 pm
sit patiently and wait my friend
im sure either placey/bmoore/or some other electrical guru will be along soon winkeye
www.oldskoolfantasy.co.uk
tomtomiS
Post Sat Oct 21, 2006 12:24 am
kev i will have a wiring diagram up here for u by saturday evening with some photos
smithy318i
Post Sat Oct 21, 2006 12:37 am
dazleeds wrote:sit patiently and wait my friend
never been quoted as a Guru before. :D
rewast
Post Fri Dec 15, 2006 8:17 pm
Awesome!
dark_sounds
Post Sat Dec 16, 2006 12:07 am
dude its easier to just work it out get the live, ignition and ground in, and then its just trial and error for the speakers, get bullet crimp connectors to them all and just switch around until you get the right wire for the right speaker.
use a multimeter to get the live and ignition,
and brown or black is the ground ;)
sorted.
Directed CompX's 12"... 2off. 1000 watts RMS, dual 2ohm VC. 90£ each!!
8600 Luna Phone 480 POSTED BNIB
J_Mac
Post Sun Dec 17, 2006 4:47 pm
as dark_sounds said, not to bad with the wiring around a car but that diagram could be chinese code to me :?
Cotty
Hartge Crew
Post Mon Dec 18, 2006 1:46 pm
dark_sounds wrote: and brown or black is the ground ;)
You sure about that, I mean really positive, hand on heart?
:teehee:
WerkdE30
Post Fri Dec 29, 2006 7:21 am
i just finished installing a new head unit.
find the purple/brown (i think) wire check with a test light. this wire should come on power with the ignition. hook this wire to the wire with the tag "acc" then find a constant live wire i used the big red wire in the loom and hook that to the wire on the h/unit that says "battery" or "bat". the brown wire is the earth. i think the white wire is the elctric aerial hook this to your aerial output and any cd stackers or amps to this wire all together.
hope this works i have a stacker and electric aerial and everythings working. the wires with one yellow and and one yellow witha brown stripe are one side of the speakers and i think the other is orange and orange with a brown stripe. but i suggest using the new wires that came with your speakers for more control and sound quality.
hope this helps.
