cheers.
single wiper conversion
confusion
cheers.
Dom
Not quite the same but storm wipers used my starlet gt to develop one on. Their work is good and cleared the screen very well. Quite useful having the washers in the arm too.
charlE30
I've fitted a single wiper system, cleans the screen nicely and mine's parked in the vertical position (will have to change for the MOT!!)
BMW E30 344i track car
BMW F31 335d xdrive
BMW F31 335d xdrive
koolz
IVE GOT ONE FITTED TO MY M3 TOO, LEFT HAND DRIVE, CLEANS THE WINDSCREEN PERFECTLY, WIPES ABOUT 85% OF THE SCREEN, BUT IVE NEVER HAD ANY PROBLEMS WITH PASSING MOT'S?
charlE30
Is it parked vertically?? I was told that it should be parked down on the passengers side for the MOT otherwise it could fail.... might depend on the testing station...
BMW F31 335d xdrive
BMW F31 335d xdrive
koolz
NO MINES ISNT POSITIONED VERTICALLY, SITS DOWN ON THE PASSENGER SIDE.
nwmlarge
did you use a kit or is there a diy fix?
charlE30
Bought a kit, you could fabricate one but it's easier to buy it
BMW F31 335d xdrive
BMW F31 335d xdrive
jonnyboy
how do you go about fabricate one.
oze30
e30matt
If your car is right hand drive then you can make your own in under an hour.
All you need to do is make one part of the linkage about 6mm longer and
streighten your original wiper arm. Bit harder on a left hand drive car but
still possiable. Made one for my rhd E30 and didn't cost me a penny.
oze30
How did you make the linkage longer? Also do you have any pics?
BadDave
I've had mine parked at the passenger side for the MOT without any problemscharlE30 wrote:Is it parked vertically?? I was told that it should be parked down on the passengers side for the MOT otherwise it could fail.... might depend on the testing station...
Vertically is definately not advised for the MOT(they should fail it for that)as it obscures driver vision
BadDave
You need a longer bit(20mm longer IIRC) that goes from the wiper motor and connects to the existing linkage, if doing it on the cheapoze30 wrote:How did you make the linkage longer? Also do you have any pics?
IIRC someone used a French car (poss renualt) part
Can't remember who it was or which exact car if was from
There is a post somewhere on here about it
Was quite a few months, maybe even over a year ago tho
