My home made ICE install
Gouki
Post Thu Sep 07, 2006 10:17 pm
I decided to make an attempt at my own flush ice install to free up boot space and to make it tidy. Its not finished yet, I still have to build a small enclose behind for the speaker to stop all the sound going everywhere and I got to get carpet. Also looking into sound proofing material e.g Dynamat. I know it aint gonna be up to Pimp my Ride standards but what do you think?
bmwe30mtech
Post Thu Sep 07, 2006 10:26 pm
Nicely done. When thats covered in carpet it will look professional. :cool:
dark_sounds
Post Thu Sep 07, 2006 10:27 pm
fiberglass is your friend :)
looks cool man, if you need a hand let me know. sound deadening etc... might be worth getting some liquid deadening, some going quite cheap atm. especially in the wheel well, cos that echoes like a bitch! (though mine dont! try and find my deadening thread)
tbh dude, i think you will utilise your boot space better if your made an enclosure and amp rack and have everything tucked under the parcel shelf, and hidden, with nothing showing, thus a stealth install, will sound better as well, and prob use less material. make it look factory, and prevent your sub getting damaged with anything u do put in the boot as leaving it exposed like this is bad, it can damage ythe cone should you take a sharp corner, bump etc..
Directed CompX's 12"... 2off. 1000 watts RMS, dual 2ohm VC. 90£ each!!
8600 Luna Phone 480 POSTED BNIB
stuartgallafant
Post Thu Sep 07, 2006 10:32 pm
looks good mate
e36boy
Post Thu Sep 07, 2006 10:54 pm
You've done a nice job on that mate, Thinkin im gonna have a go at doin a DIY install, Wanna make some pods/enclosures and mold some fibre glass 'N' that. Figure its gonna be harder than it looks though, Ive worked with fibre glass before, Love the stuff.
e30bemer
Nutters
Nutters
Post Fri Sep 08, 2006 10:07 am
Looks good there!
wanna do something like that aswell, mine boot is being taken up 2 12's
or might just go smaller!
mikey-t
Post Fri Sep 08, 2006 10:14 am
i used to do this as a job and i tell you what that isnt half bad mate, out of interest hows it all built underneath i.e what size box is it mounted in , sealed / ported etc,,
m3ben05
Post Fri Sep 08, 2006 10:20 am
Dont be tight with the sound deadening mate, iv lost count of how many times iv laughed at people rolling up to ace cafe convinced they are the shit with their system up, not realising the rear of their car sounds like its falling apart.
miniblob
That'll look pretty cool when it's carpeted!!
However, gotta agree with dark_sounds 'cos you've pretty much lost your whole boot by doing that!! That's fine of course if you don't mind that - most of my previous cars have had no boot left when my installs have been in - that's what back seats are for!!
But, if you put anything in the boot, that subs gonna get wrecked!!
I plan on putting a couple of my small amps in the spare wheel well with some other bits and hiding them completely!! Then my big amp for the sub will be flush mounted on one side of the boot and the sub will be in a removable enclosure, so i can use the whole boot if i need to!! Hopefully!
327 Touring with bass!!!
Gouki
Post Fri Sep 08, 2006 10:31 am
i still got to build a sealed enclosure which wont take long for the sub as underneath there's no enclosure for the sub. I'm getting a bit of vibration and rattle from inside with all the bass leaking everywhere! I'm looking to use Liquid deadening to get things tight inside the boot. I dont keep many things in the boot so not too worried bout the sub but a speaker grill could help. Deciding on carpet colour choice was thinking of red just to create a bit of impact like the one in the other cab as that has a similar install except the sub is in a separate enclosed box.
dark_sounds
Post Fri Sep 08, 2006 11:06 am
also another thing i noticed, you might need to double up on the baffle, even its its just a bit around the sub itsself, that mdf wil llack strength and will flex due to the size of it. not good!
even if its like a extra 18mm mdf panal that goes around the sub and even creat a border to the amp, and then you can carpet the rest in black and trim the raised panal in red, look better no?
