AMP WIRING ROUTE>>>>>
delphini
Post Sun Aug 06, 2006 11:50 pm
HELLO TO ALL , just thought i would share a little trick i used on my cabby while wiring the amp a few weeks back. I'M not sure how those of you who are running an AMP wired theirs but i decided to use a pre-existing hole in the forward bulkhead and actually since my car no longer has a working a/c unit i utilized the intrance/exit holes where the a/c lines go through the body just next to the battery and made a grommet from the existing rubber to carry the power lines for my amp. Hope this may be useful to those planning to install amps for their systems in the near future best of all no holes need to be bored and it looks like it was meant to carry wiring and cables anyhoo. :thumb:
b.t.w i run 1000w with 2- 12's in the boot kicks like a bitch, gotta turn her up a bit when the top is down i guess cause the top muffles the tunes a bit BUT HEY ITS ALL GOOD !!!!!
