ICE question
monty68
1989 'E' 318i E30. Hi all, I've just bought a new Kenwood head unit to replace the tape/radio blaupunkt unit. My new cd head unit has the lock power connector on it. My question is as stupid as it might seem, what connector does the blaupunkt radio have on it?? Many thanks to anyone that can help
cliffybabe
- Powered by Nelly
every model is different mate have u got a standard iso on the exsisitng wiring loom
monty68
Hi cliffybabe, thanks for getting back to me. yes it has a standard iso, i fitted it yesterday but it won't store the stations when I switch the engine off? Any ideas
fowler
- Boost Junkie
you have no got the perminant live hooked up that is wahat is needed to keep its memory
EX A-Tech Workshop bitch !!!
gone but not forgotten
chu346
I think you need to swap around your 12+ and accessory live wires
JAFF
you shud have a yellow wire this is for memory hook this up to your perment live feed it shud store then
monty68
I'm going to sort it this weekend, it's doing my head in now
. Thanks for the help all, cheers
Steviec
As above really, there should be a yellow wire and a red wire coming from the rear of the head unit, both of these should have bullet type connectors, simply pull them apart and attach the red wire to the yellow and the yellow to the red. Its quite a common thing to have to do and will take all of 2 mins.
<a><IMG></a>
