what do we think of these then??!
tregzybmw
Post Mon Jul 03, 2006 11:33 pm
Supersport E30 Lowering Spring Seats
lowering spring seats
BMW 3er (E30) 11/1982-05/1993
Limo,Cabrio,Coupé,Touring
lower in mm: 10-20mm
A fun drive that's really close to the road! If conventional suspension kits don't get you close enough to the ground, then the special SUPERSPORT bushings and bearings are an absolute must for you! Suitable for many types of vehicle, by installing these you get an additional depth of 10 to 20 mm.
Price: £41.99
so, i get a nice suspension kit, that lowers it 40/60mm, AND also put these on, then i have lowered it by a total of 70-80mm.
is it that simple and safe??!
egk2
Post Tue Jul 04, 2006 5:51 am
I have these, they lower the front end an additional 10mm, since they
were a bit wider than stock units they rubbed against the strut tower
housings, I grinded the hats down to stock diameter and now I'm good.
These brought my front end down to the perfect height since I'm running such a short tire.
2.8L M20 Stroker
nasir325ic
Post Tue Jul 04, 2006 8:09 am
sounds good 80mm, where can i get a set?
does the set include front and rear?
DaveD
E30Zone Wiki Specialist
Post Tue Jul 04, 2006 8:24 am
