Found some e36 leather
wondering how hard it is to fit.will the rears go?
any help would be great.
e36 coupe seats into e30
johnna
- E30Zone Irregular
somewhere between very difficult and impossible. Probably just lined up alongside the expression MOT failure.
Maybe the subframes will swap, but I doubt it.
The fronts will need re-inforcing plates in the car floor.
The rears are a different set-up all together, the rear seat backs are 3 piece in an e36, yet one piece in an e30.
ad318i
yeah u can there is a lil work you need to do on it though...
...bootyman had them on his car
if you use the forum search you should get some good results on there
1989 Alpine White 318i 4 Door - Got Scrapped When I Was Abroad
1993 Metallic Green 316i Touring - Im Selling it before i move back to Greece, http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0239342139
nav786
yes it can be done, there is a few guys on here who have done it. you will need to mod the base frame to get them to work.
FOR SALE
SONY PSP'S £100
amy325
i reckon i will keep looking for a set of e30 leather,prefer the origanal look any way.cheers for the advice
cliffybabe
- Powered by Nelly
i have started to fit my seats the rears have holes already but i have had to drill the front holes into the floor plan and support with large thick washers
theirs a pick of the seat int he ca ron bmw chat forum
johnna
- E30Zone Irregular
"i have had to drill the front holes into the floor plan and support with large thick washers"
This is insufficient. The securing bolts will shear through the floor panels in a crash situation. The sturdy washers need welding in place and I'd recommend some strengthening braces welded in place too. 2mm ish thickness.
cliffybabe
- Powered by Nelly
cheers mate never knew that even though i asked the MOT station round the corner, but for safety im gonna get it done asap
johnna
- E30Zone Irregular
Thanks for taking the advice in the way it is intended.
I have offended others with this advice before. Even if it is over-kill for the mot, consider this:
Ruining a car in a crash is one thing, but it becomes a real tradgedy if your seat mounts fail.
The moving seat adds weight to your momentum, the seat belt won't save you as it clips into the seat, not the floor pan.
When you get them fitted please post up the pics!
