would like my rears to be grids of l.e.ds?
liam012
Post Tue Feb 14, 2006 10:52 am
Is this possible? i dont want round afterburner look but i fancy a rectangular grid of about 40/60 l.e.d.s for the brake size lenses would look fabulous on the rears of my facelift? how would i go about doing this?
eun
Post Tue Feb 14, 2006 11:48 am
this could be done as anything is possible
but are you trying to make it look like an e46 or even
e36 as some of those have led lights?
imo it will look a bit dodgy but well prove me wrong and
i may chance my opinion :wink:
mrLEE30
Post Tue Feb 14, 2006 2:43 pm
thought about this my self, problems you need to overcome are 1. opening the lamp units, i tried this once by heating to try and smoke the rear lenses but from the inside of the lens, it is not possible without cutting the plastic lens off of the lens housing. refitting would be a nightmare due to water getting inside the lens etc, will require some good thinking!!
2. your break check light will come on as the LED's will not draw the same amount of current as a bulb so the check computer will see it as a blown break light.
3. mounting the LED's so that they all appear equally bright from the rear.
actually doing the job should not be too hard, buy super bright LED's and a coule of resistors from RS or similar, get your soldering iron out and away you go.
mrlee
stevetigger
Post Tue Feb 14, 2006 5:36 pm
I did the brake lights and the N/S indicator.
Im not sure the indicator looks any good, but the brake lights dont look half bad!
